Like Tree11Likes
Pinion gears..
Old 12-07-2017, 09:20 AM
  #16
Whatever pinion you boy they should use M3 screws.
Reason: if a 1.5 mm driver is jumping in the the hex, just use the 1/16 driver which is 1.6mm to easily get rid of that worn grub screw.
Cruise
CruiseM is offline
Old 12-07-2017, 06:26 PM
  #17
bubbaslash's Avatar
We run Robinson pinions. 1/16" driver. A little more surface area to grab onto. And we use the blue gel Loctite in the "chapstik tube". Does the job but releases fasteners when you need them to come out.
bubbaslash is offline
Old 12-07-2017, 07:52 PM
  #18
I've never used loctite on a pinion gear
faqcya is offline
Old 12-07-2017, 10:47 PM
  #19
Don't feel loctite should be needed on pinion.
Hands001 is offline
Old 12-08-2017, 05:04 AM
  #20
Trader Rating: 31 (97%+)
I used to feel the same when I first got into racing... but when you throw a couple pinions during a race (especially a main) then you start to learn how important thread lock is... I've also learned that gel works better than liquid and will also use an alcohol swab to clean both surfaces by driving the screw through the swab and into the pinion first to get it nice and clean before applying thread lock... I also use a micro torch for 5 seconds to melt the glue when I need to remove any screws to eliminate any risk of stripping heads.
billdelong is offline
Old 12-08-2017, 11:35 AM
  #21
Good stuff Bill
SouthFloridaApp is offline
Old 12-08-2017, 06:47 PM
  #22
sickpuppy1's Avatar
Trader Rating: 32 (100%+)
Ive used the chapstick type of loctite on gear sets and never had a prob. Its kind of a step between liquid and nothing,lol Holds, but not so tight I need to heat it. Oh yeah, blue.
sickpuppy1 is offline
Old 12-10-2017, 07:56 AM
  #23
platgof's Avatar
and that tube lasts forever!
platgof is offline
Old 12-10-2017, 08:20 AM
  #24
I started racing in 1990 and I've never lost a pinion from not using loctite on the set screw. I have lost other metal to metal screws back before I used loctite but never a pinion. I do like the tip about the micro torch.
faqcya is offline
Old 03-28-2018, 02:08 PM
  #25
sooooo what is the consensus on setting mesh. Nitro guy going to electric, reading a lot of different methods. So the paper method will work?
Evoking1230 is offline
Old 03-28-2018, 02:42 PM
  #26
EbbTide's Avatar
Trader Rating: 39 (100%+)
Paper method will work on everything except the larger pinions like Mod1. For those I set manually. Though you could also double up the paper and get pretty close to ideal on Mod1
EbbTide is offline
Old 03-28-2018, 02:44 PM
  #27
the rc guy's Avatar
double folded paper works 100% on Mod 1 that's about the only gears i run.
ta_man likes this.
the rc guy is offline
Old 03-28-2018, 03:04 PM
  #28
vwduud's Avatar
Trader Rating: 48 (100%+)
I do the same. I run Losi Mod 1 plastic spur gears, which in my area a lot of guys are scared of, due to stripping, and go to metal spur gears on their eBuggies. I've always used the double paper method across all brands and have never stripped out a plastic spur gear with this method. Consistent and quick to set/reset as gears wear.
vwduud is offline
Old 03-28-2018, 03:14 PM
  #29
EbbTide's Avatar
They're scared because they can't mesh gears apparently lol. I've also kept plastic pinions on my 1/8 kits and never stripped. Just like with the eb410 guys killing gears, it's all in the mesh
EbbTide is offline
Old 03-29-2018, 04:12 AM
  #30
For what it is worth I have been using MIP tools since the 1990's. Presently, I own two newly purchased 2.0 mm MIP tools, one older Dynamite 2.0, and now 1 Arrowmax 2.0 mm tool. As I have stated the MIP tools are near new. I have found that the MIP tools are smaller than the Dynamite and Arroxmax tools. Hence, I will use my Arroxmax when a screw is a bit loose fitting. This has saved me countless numbers of times in order to get a screw out that has play in it with the MIP tool. Experienced racers know that it is time consuming to get out a stripped or loose screw. FYI I always replace suspect screws..... I have had my Dynamite tool for many years and thought it was an anomaly, and used it only for loose fitting screws because I did not want to wear it out. I am now of the belief that the MIP tools are not quite the same snug fit as Arrowmax or Dynamite. If you own all MIP tools I recommend purchasing a couple of Arrowmax tools, or at least compare tools on a screw from other racers at your track. One will be amazed at the differences in play with the screw heads with different tools. FYI I own about 7 MIP tools..... I posted this to help others......
