Ball bearing differential
How do you permanently lock a ball bearing differential?
you can glue it . i dont see any diff if u went to a spool ...just more money tossed out the window
R/C Tech Elite Member
I have had a look through your threads. All of these JB weld silly puddy methods are for gear diffs. You have a ball diff which has the huge benefit of being adjustable. All you have to do is is crank down the nut (PN 110097) all the way. If that isn't tight enough remove the diff spring and replace it with washers of the appropriate size ... and crank down the nut.
https://www.rc-mst.com/_upload/down_...260401302a.pdf
