Go Back  R/C Tech Forums > General Forums > Drag Racing Forum
Technical Questions 124019 for Speed Runs >
Like Tree1Likes
  • 1 Post By gigaplex
Old 01-28-2022, 12:50 AM
Default Technical Questions 124019 for Speed Runs
Hi All,
I am building a WL Toys 124019 for high-speed runs. I am starting to get beyond my technical knowledge and would like guidance on technical issues.
I have installed the 15 T Pinion Gear on a Racerstar 2445 3600kv Motor Senseless Brushless Waterproof and installed the motor on the Motor Mount. But I don't think the stock plastic spur gear will last long with the 15T pinion metal gear and the stock plastic spur gear and 15T pinion gear seems to be slipping, I will open up to confirm. I believe the stock gears are 27T pinion and 44 spur.
I am trying to follow the quadifyrc brushless upgrade. A couple of questions;
  1. Is that correct to use the 15 T Pinion Gear on a Racerstar 2445 3600kv Motor Senseless Brushless Waterproof with stock Spur for speed runs?
  2. I have ordered a replacement metal stock spur gear to replace the plastic gear. What are the best gears to use for speed runs with the 124019 ?
I am using this
motor mount motor mount
Thank you, cheers
WL Toys 124019 build:
  1. 124019 $120 with shipping
  2. Flysky FS-GT5 Transmitter w/ FS-BS6 Receiver Flysky FS-GT5 Transmitter w/ FS-BS6 Receiver
    $91 with shipping
  3. GPS SkyRC GSM020 $63 with shipping
  4. HobbyWing QuicRun 1/16 Brushless WaterProof 30A ESC WP-16BL30 $33 with shipping
  5. Remo P6973 Rubber Tires and Wheel $29 with shipping
  6. Racerstar 2445 3600kv Motor Senseless Brushless Waterproof $17 with shipping
  7. Motor Mount Motor Mount
    $12 plus shipping
  8. 4Pcs Steel Front Rear Universal CVD Drive Shafts 4Pcs Steel Front Rear Universal CVD Drive Shafts
    $12 plus shipping, need to install
  9. ZeckTeck Swing Arm Metal Reinforced Swing Arm Set ZeckTeck Swing Arm Metal Reinforced Swing Arm Set
    $25 with shipping, great addition stops dog bones from popping out
  10. JX Digital Servo 17g Metal Gear JX Digital Servo 17g Metal Gear
    $20 with shipping
  11. Pinion Gear $7 with shipping
  12. Metal Aluminum Gearbox Housing Covers Metal Aluminum Gearbox Housing Covers
    $23 with shipping, plastic housing broke
  13. Total $452 with shipping
Need to order:
3S or 4S Battery
museguy is offline
Old 01-28-2022, 12:58 AM
Hi all,
I left on message for Stew Mac and I heard back;
"I prefer castle esc. The mamba monster X or the older mamba monster 2 are both really good.
Colt RC make some great Le Monds type bodies. A good motor combo would be the Mamba Monster X and castle 6900kv 1410 motor on 3s"
I was surprised the Mamba Monster X is about the same price as the XR8 Plus.
I would appreciate any suggestions, thank you !
Cheers
  2. Colt RC Porsche 962 Body $40 plus shipping, need to confirm will fit on chassis
  3. Castle 6900kv 1410 $92 plus shipping (6S, Sensored,
  4. Castle Mamba Monster $150 plus shipping
  5. Foam Tires $30
  6. Power HD R12 $45 plus shipping
  7. CNHL Battery $100, 3S or 4S
  8. Gears $30
  9. Castle Program Card $40
  10. FlySky FS-BS6 Receiver FlySky FS-BS6 Receiver
    $20
  11. XT90 Connectors and Cables $30
  12. Total $697
museguy is offline
Old 01-28-2022, 01:22 AM
Hi All,
Does anyone know what body shell Birmingham GT RC uses on his 124019? His 124019 is the closest I have found to what I would like to build, 124019, Castle ESC, TP motor 3540kv, 4s in parallel, Castle Mamba monster.
I asked him in the comments with no reply and I also asked Delta Plastik USA, they said it was not one of their bodies. Thank you
124019 speed run and about the car 13:37 to 24:22
124019 GT body shell
museguy is offline
Old 01-28-2022, 03:29 AM
the rc guy's Avatar
will esc handle 3 cells ? unlikely and it will be a good smoke show on 4 cells..id go up in pinion size for speed runs 20+
the rc guy is offline
Old 01-28-2022, 09:17 PM
Dear the rc guy
Thank you for getting back to me !
I am starting with the HobbyWing QuicRun 1/16 Brushless WaterProof 30A ESC WP-16BL30 and Racerstar 2445 3600kv Motor Senseless Brushless Waterproof until I can get things sorted.
With the brushless setup and the smaller 15T Pinion Gear 44T stock plastic spur, the car is slower (22 mph) than with the brushed motor and 27T pinion and 44T plastic spur (32mph).
  1. Should I go back to the stock 27T pinion and 44T plastic spur? I have ordered a metal 44T spur gear.
  2. Is there a way to determine gearing and make the gearing easier to change?
I plan on buying a Castle 6900kv 1410 and Castle Mamba Monster once I can get the chassis sorted.
Thank you !
museguy is offline
Old 01-29-2022, 12:19 AM
gigaplex's Avatar
That ESC can handle 3S but definitely won't work with 4S.
gigaplex is offline
Old 01-29-2022, 12:25 AM
Dear ​​​​​gigaplex
Thank you for your reply!
Can you give any feedback on the gearing ?
Thank you !
museguy is offline
Old 01-29-2022, 04:02 AM
gigaplex's Avatar
Originally Posted by museguy
Dear ​​​​​gigaplex
Thank you !
I don't know where it should be geared but there's a big difference in those two pinions you've tried. Generally, the bigger pinion will go faster but will lose acceleration. Check temperatures of the motor and ESC after each run.
museguy likes this.
gigaplex is offline
Old 01-31-2022, 01:16 AM
Thank you gigaplex
Very much appreciated. I have ordered the stock metal gears with (with the larger pinion), I will test next week.
Cheers
museguy is offline
Old 01-31-2022, 01:46 AM
Hi All,
I am trying to learn about gearing and found R/C Gearing 101. If I am understanding correctly, for high-speed runs you want about 1:1, pinion, and spur.
If the stock gears are 27T pinion and 44T spur, that is a total of 71 or a desired 35 pinion and 36 spur. I will start researching 48 p gears.
Also found a great thread about modified 124019 cars.
Cheers
museguy is offline
Old 01-31-2022, 05:23 AM
gigaplex's Avatar
Hi All,
Cheers
I'm not sure where that 1:1 ratio comes from for the pinion and spur. The internal ratio of the drive train, tire diameter, mass of the vehicle, and motor performance all make a massive difference.
gigaplex is offline
Old 01-31-2022, 06:03 AM
Nineball's Avatar
1:1 just gets you the most possible speed out your gearing, making it essentially direct drive with the only reduction being in the diff.
The problem I found was WLToys use an odd gear pitch... something like mod 0.5.... and the motor mount isnt adjustable. Maybe you worked around that all, but it sounds like you're still playing with the stock gear ratio.
Nineball is offline
Old 11-24-2023, 09:31 PM
I am still using my 124017 which is just the 124019 with brushless. I have installed a slipper clutch and 48p gearing on mine. Currently running a 52t spur gear with a 34t pinion. Motor is a 380 size surpass hobby 8.5 turn sensored with a hobbywing quickrun Bl120 esc on 2s pb is currently 56mph and on 3s pb is currently 67 mph. Still have a ton of room for gearing as the motor runs super cool. I want to see what i can get out of it before i go to my 540 size 4.5 turn sensored motor. I tried to do ost a couple pictures of the gearing mod but site wouldn’t allow me to.
Rickz is offline
Old 01-22-2024, 01:23 PM
Did you throw in your 540 yet and what results did you get?
nichols174 is offline
