17.5 boosted
Old 11-30-2022, 04:31 PM
Default 17.5 boosted
Looking for information on the correct way to boost and gear a 17.5 sprint..
protrk3 is offline
Old 12-16-2022, 01:20 AM
I'm really curious about the number 17.5
incidentnuts is offline
Old 02-17-2023, 07:06 AM
Trader Rating: 16 (100%+)
Most 17.5 classes don't allow boost. Does yours?
Silverbullet555 is offline
Old 02-17-2023, 07:38 AM
jasburrito's Avatar
If your running 90% to 100% throttle do you really need to boost? I just started running street stock oval myself. I have the timing high on my 13.5 at 54 degrees. Well above 6 amp. Witch gives me 42000 rpm. Any advice would be great. Thanks. If boosting I would set timing at 35 and add 20. Gear for like 13.5 ,8.5 ish or higher.
jasburrito is offline
Old 03-26-2024, 06:51 AM
Increase the ESC timing to boost power. However, be cautious as too much timing can lead to overheating. Start with a moderate increase and adjust based on the motorís temperature and performance. The FDR is crucial for balancing speed and acceleration. A lower FDR (smaller pinion or larger spur gear) will increase acceleration but decrease top speed, while a higher FDR (larger pinion or smaller spur gear) will do the opposite. For a 17.5 motor, you might start with an FDR around 4.0 and adjust based on the track size and motor temperature.
natoh is offline
