four wheel to two
Old 05-03-2021, 06:08 AM
Default four wheel to two
Any know if I could covert my blackout sc truck to two wheel from 4 wheel to run on dirt oval
BigRich is offline
Old 05-03-2021, 07:08 AM
Trader Rating: 16 (100%+)
It's possible, but generally, the geometry is significantly different in the front end and the conversions in that direction don't work too well.
Silverbullet555 is offline
Old 05-04-2021, 10:14 AM
the rc guy's Avatar
Big it can be done.. Id actually go with front wheel drive. lock main diff .remove rear drive shaft and wheel dogbones...I kinda like the way a rc truck would pull outa a turn.make sure ur track will allow fwd or just do rear.
the rc guy is offline
Old 05-04-2021, 05:53 PM
thanks a bunch to buy a ready to run is out of my budget lol. too expensive so if I can use my blackout chasis would be cheaper
Richard
BigRich is offline
Old 05-04-2021, 05:55 PM
thank you very much a lot to consider
Richard
BigRich is offline
Old 05-05-2021, 01:52 AM
fyrstormer's Avatar
You can simply disconnect one of the axles, but that won't change the weight balance or suspension geometry to optimize the truck for running with only two powered wheels. Those differences are the reason why separate 4WD and 2WD chassis exist.
fyrstormer is offline
Old 05-05-2021, 04:36 AM
the rc guy's Avatar
You cant just remove the front drive shaft you will need to lock the main diff b4 you run it.
Old 09-21-2023, 06:56 AM
JDMR's Avatar
I did this in a 1/18th once, it was one of the fastest car on the track. go for it... Lock the center diff somehow
JDMR is offline
