Like Tree2Likes
  • 2 Post By TeamSkunkwerks
Dirt Oval Set up
Old 12-04-2018, 08:35 AM
Default Dirt Oval Set up
Just wondering what kind of set up I would need to make my what used to be a SC and now a dirt late model car pull the left front wheel off the
ground when coming off the corner. Just wanting to have a little fun. I know it wouldn't be the ultimate setup for traction but just wondering how
to make it do this.
drsmith411 is offline
Old 12-04-2018, 06:25 PM
R/C Tech Elite Member
TeamSkunkwerks's Avatar
Trader Rating: 127 (100%+)
Talking Try this.......
Phase 1 (going into the turn)
If the vehicle is loose at turn entry then..(needs more traction)
(1) Right front spring is to soft use a harder spring
(2) You need to add more crossweight - by adding a round to the right front spring (add weight to the left rear tire).
(3) Change left front spring to a softer spring.
(4) Lower chassis - keeping it level with the rear.
(5) Reduce front right caster (no less than 2 degree min.)
OR If the vehicle is pushing into the trun entry then..
(1) Right front spring needs to be softer.
(2) You need to reduce the crossweight - by taking out a round to the right front spring (add weight to the front left tire)
(3) Increasing right rear spring tension by one round
(4) Increase front right caster (6 degrees max.)
Phase 2 (the middle of the turn)
If the vehicle is loose in the middle of the turn then...(needs more traction)
(1) Increasing the crossweight by adding a round to the front right and left rear evenly (add weight to the left rear tire)
(2) Use a harder spring to the left rear
(3) The right rear spring needs to be decrease a round (less spring tension)
OR If the vehicle pushes in the middle of the turn then...(needs more steering)
(1) Decrease crossweight by taking out a round to the front right and left rear evenly
(2) Use a softer spring to the right rear
(3) The right rear spring needs to be increase a round (more spring tension)
Phase 3 (coming out of the turn..)
If the vehicle is loose coming out of the turn then..(needs more traction)
(1) Stagger needs to be decreased on the right side
(2) Increase crossweight by adding a round of spring tension to the right front and left rear evenly (add weight to the left rear tire)
(3) Check if right rear spring tension is to much - if it is then take a round out of spring.
(4) Decrease rear springs evenly to the right and left rear.
(5) Use a soft tire in the rear
OR If the vehicle pushes coming out of the turn then...(needs more steering)
(1) Stagger needs to be increased on the right side if present.
(2) Decrease crossweight by reducing a round of spring tension to the right front and left rear evenly (add weight to the front left tire)
(3) Increase right rear spring tension a round.
(4) Increase rear springs evenly to the right and left rear.
JatoTheRipper and Andy Koback like this.
TeamSkunkwerks is offline
Old 12-11-2018, 06:17 AM
Trader Rating: 95 (100%+)
Soft rr spring and alot of preload on rf and lr will do that.
latemodel13 is offline
Old 12-11-2018, 07:32 AM
Ovaloldtimer's Avatar
This;
A+ for reading comprehension
Ovaloldtimer is offline
