In the Market
Old 01-05-2017, 09:31 AM
Default In the Market
I am looking to buy for the first time a brand new scale/trail truck. I have always bought my crawlers used. I have $400 and I want to buy a new truck. What would you suggest would be the best truck I could buy? I would be using the truck for mostly trails and minor rock crawling. Kit or RTR doesn't matter. I would prefer a kit because you get better parts that way, but if you think there is a pretty substantial RTR that would be better let me know. Right now I own a lightly upgraded Axial Scx10. Thank you for your time and I look forward to reading your suggestions.
MikeyBigs is offline
Old 01-05-2017, 02:47 PM
OSRC's Avatar
SCXII and Ascender kits are about as good as they get.
OSRC is offline
Old 01-05-2017, 03:29 PM
So you would say a kit over RTR?
Old 01-05-2017, 03:56 PM
Rug Runner's Avatar
Trader Rating: 55 (100%+)
Kit vote for sure, upgrades!
Rug Runner is offline
Old 01-05-2017, 04:07 PM
OSRC's Avatar
Yes.
OSRC is offline
Old 01-06-2017, 06:16 AM
For the Vaterra Ascender the only difference between kit and RTR is the kit has a C chassis. Does that really make that big of a difference in performance?
Old 01-06-2017, 06:55 AM
OSRC's Avatar
While there is a significant difference from the Axial RTR and kit, the Vaterra mechanicals are the same for the kit and RTR. Only difference is the assembly, electronics, and price of course.
OSRC is offline
Old 01-06-2017, 07:06 AM
Do you have a lot of issues with the Ascender? I keep reading that the torque twist is a huge problem.
Old 01-06-2017, 03:47 PM
OSRC's Avatar
Zero issues. The TT was annoying stock, but not a deal breaker. I tuned mine out initially with outboarding the shocks and a little more spring tension. I added a rear swaybar now and it's dialed.
I saw your thread on RCC (you're getting good advice over there as well) I will add I have a Sawback (Great rig, not in the same league performance-wise, but great) The 4LS/Komodo is most likely a decent performer also - I'd recommend both if you want something different.
I also have an RC4WD Gelande and in the past had a TF2. The TF2 never made it through a single trail run. Screws backed out or stripping, rear ring and pinions stripping, axles breaking - I had all kinds of issues with it. 2 of the others in our club were junk as well. Of the three we had, all of them were sold long ago - and good riddance. The Gelande is better, but only if you are into scale driving. it's not meant in any way for hardcore terrain.
OSRC is offline
Old 01-09-2017, 07:11 AM
So overall you would say I can't go wrong with the Ascender? I am going to probably pick the K10. Its a shorter wheel base and I am hoping for a better performance. Or do you feel I still go with the kit version of the of the K5 because I get all the upgrades?
Old 01-09-2017, 12:16 PM
I think I am just going to get the kit Version of the Ascender. Seems to me to be the best option. I have a RC4WD 35T motor do you think it is a good motor for the truck?
Old 01-10-2017, 10:16 AM
What type of servo would work good for the truck? I think I have a Hi-tec HS-645MG. Will that work in the Ascender?
Old 01-10-2017, 04:00 PM
OSRC's Avatar
I replied over on RCC...I run that exact combo in mine. I do have the 2 speed installed, but that's just for fun.
Not that you can tell, but they're on there.
OSRC is offline
Old 01-10-2017, 04:04 PM
I think you might want a little stronger servo than that. the RC4WD 35T motor would work fine in it. The RTR version also comes with a 35T motor. For an inexpensive EXC I would look at a Hobbywing Quickrun Waterproof 1080. Programable and reliable.
JDM74 is offline
Old 01-11-2017, 05:45 AM
I ended up buying The Ascender kit with tekin redline 35t brushed and Hobbywing Quicrun 1080. All I need is a lipo and I am done. Any Recommendations? I know I need shorties now and 2s or 3s is best but what volt and Mah? Is there a brand better then others?
