Go Back  R/C Tech Forums > General Forums > Crawler Room
Wraith Spawn RTR vs Kit >
Old 11-13-2016, 04:08 PM
Default Wraith Spawn RTR vs Kit
Hello,
Considering buying a Wraith. Are there any big differences between the kit and RTR in terms of components? Does the kit come with any upgrades?
DrVest is offline
Old 11-13-2016, 07:27 PM
hotrod87's Avatar
Trader Rating: 252 (100%+)
This will help. All the info on differences is on Axials site.
http://www.axialracing.com/t/vehicles
hotrod87 is offline
Old 11-14-2016, 08:12 AM
Trader Rating: 15 (100%+)
If you're getting it for bashing, the plastic links on the RTR will be fine. If you're wanting to do any crawling you NEED the aluminum links that come with the kit. The plastic one's will bend under the slow-speed pressure. Plus the Kit comes with the CVD's which are not only stronger than the RTR but allow more steering angle too.
John82601 is offline
Old 11-14-2016, 09:18 AM
hotrod87's Avatar
Biggest difference in my opinion is the universals for helping steering. Plastic links are slicker than aluminum on rock although they do bend. Best aluminum link is for steering and if you do that you need aluminum chubs and knuckles or the plastic ones will get broke or at least that always happens to me. Still it comes down to your budget
hotrod87 is offline
Old 11-14-2016, 09:36 AM
git the kit the upgrades are worth it out of the box i had the rtr wraith and always wanted more steering out of it
maxmad is offline
Old 11-14-2016, 10:45 AM
hotrod87's Avatar
I agree as long as budget doesn't interfere.
hotrod87 is offline
Old 11-27-2016, 04:19 PM
JatoTheRipper's Avatar
The Axial Bomber is what the Wraith should have been IMO. Consider it. The kit is way better than the RTR in both cases. But in the case of the Bomber it's the best, most well upgraded Axial kit.
JatoTheRipper is offline
