Go Back  R/C Tech Forums > General Forums > Crawler Room
Newbie questions >
Newbie questions
Newbie questions
Old 09-20-2015, 05:59 PM
TheRockman's Avatar
Trader Rating: 37 (100%+)
Default Newbie questions
Can I use my own radio? Radiopost
What is it called when you let off the throttle on an incline and it locks down (doesn't roll)...and how do I get it?
Is the Honcho capable of doing question number 2?
TheRockman is offline
Old 09-21-2015, 04:08 PM
flou's Avatar
Trader Rating: 18 (100%+)
You are talking about drag brake.and most escs have it.is in the programming options. The more drag break applied the faster it stops and harder it holds.
flou is offline
Old 09-24-2015, 09:26 AM
weck's Avatar
would be easier to help you if we knew what ESC you had. Post up the model and someone should be able to help you figure out how to setup your drag brake.
weck is offline
