Gear Reduction Unit
Gear Reduction Unit
hi what are the diff. between and uses of the following:
GRU 2:1
GRU 3:1
GRU 4:1
GRU 1:2
thanks
GRU 2:1
GRU 3:1
GRU 4:1
GRU 1:2
thanks
the first 3 are slow and put out torque. every 2,3 or 4 rpm input, you get 1 rpm output.
last one is faster. 1 rpm in,2 rpm out
is it mean that 2:1 will slow down my motor and 4:1 is the slowest (having same motor power)?
assuming i have 35t which is best GRU for this motor or any chart to look on?
thanks
thanks
i dont know which is best. iv never ran one.
is it a scale truck or comp truck your looking to put 1 in?
from what iv seen,most people run them in scalers as compact transmissions,mounted in the front of there truck and feeding power to a transfer case so they have clearance for a full interior
I bought the two GRUs as a test. I want to see the difference between a 2:1/higher torque 65t motor vs. a 3:1/lower torque 45t motor.
I've only driven it about 15 minutes but the 3:1 with 45t is an absolute beast. It is far superior in crawling than just using a high tq motor with no GRU.
All gear reductions increase torque, but given the same 35t motor the 3:1 will yield more low speed control and torque. The trade off will be a slower top speed. It all depends on the application.
I have 35t and i'm planning to get the 2:1 do you think its ok?
