Go Back  R/C Tech Forums > General Forums > Crawler Room
scx10 tire question >
scx10 tire question
scx10 tire question
Old 12-25-2010, 08:02 AM
sst4nbr1's Avatar
Default scx10 tire question
do most put vent holes in the rims or not??
sst4nbr1 is offline
Old 12-25-2010, 10:13 AM
Briguy's Avatar
Trader Rating: 125 (100%+)
In both tires and rims .
Briguy is offline
Old 12-25-2010, 04:14 PM
ae-Dan's Avatar
Trader Rating: 39 (100%+)
i do only the tires. i feel that the ones in the rim let dirt and water in but the ones in the tires let stuff out. imo
ae-Dan is offline
Old 12-25-2010, 07:21 PM
*Super*'s Avatar
I just do rims. If you put holes in the tires they tend to catch and tare. It doesn't matter about dirt and water it will get in either way.
*Super* is offline
Old 12-25-2010, 07:51 PM
How does yours catch and tear? I've seen bead rips but never tearing at the vent holes.
Dirt isn't a problem since beadlocks allow you to remove the tire and wash the foams. It's the glued on ones where you can't clean them so the wheel vents help the dirt and water get out when the wheel spins. Rim vents can't do that all the dirt and water stays inside.
AreCee is offline
Old 12-25-2010, 07:56 PM
*Super*'s Avatar
The tire wads up and catches a corner of a rock or part of the link by the wheel. That's what happened to me anyway.
*Super* is offline
Old 12-26-2010, 05:26 AM
ae-Dan's Avatar
i dont know how you make holes in the tires but i use a leather punch and you only want 2 holes across from one another. i dont know how you are tearing tires have you got a pic of your holes?
ae-Dan is offline
Old 12-26-2010, 07:36 AM
jeeperscreeper's Avatar
Trader Rating: 79 (100%+)
i prefer venting the rim, i like my tires uniform with no holes in them
jeeperscreeper is offline
Old 12-26-2010, 10:40 AM
*Super*'s Avatar
Nope, junked them. I just vent the rim, works best for me.
*Super* is offline
Old 12-26-2010, 06:07 PM
if u run near any water, dont bother venting rims it will just let the water in to rot out your foams,
with my swampers ont hte honcho they are just weghted and sealed, the g8 compound is soft and they bag plenty, with the flat irons that are a bit harder, u can put a rubber band around the tyre to squish out some air as ur putting them on the rim to help them bag out a bit more.
cheers ads
adski is offline
Old 01-03-2011, 04:55 PM
cementsurfer86's Avatar
I second that on the TSL's.
They seem to work better when they are sealed up without holes, seeing as how they are soooooo soft and deform pretty well anyways.
cementsurfer86 is offline
Old 01-03-2011, 08:00 PM
Trader Rating: 9 (91%+)
all depends on what kind of crawling your doing.
since the op has a scx, hes doing scale stuff, so venting isnt the best idea.
the flat irons arent that bad, but you need to weight the wheels down. for just general crawling/trail playing, 5-7 ounces in the front wheels, and 3-4 in the rear.
mainly the venting is for rocks/comp only. and it doesnt matter wether its on the wheel or tire.
one plus of doing it on the wheel, is you can ''tune'' it. if you want it sealed, simply put a small set screw in the hole or holes.
jbeane is offline
Old 01-03-2011, 08:28 PM
Suspended
Trader Rating: 27 (97%+)
My scx10, i have the foams removed, and the rims vented, it crawls like a MOFO!
FTSC10 is offline
Old 01-03-2011, 08:41 PM
with what tires???? christ sakes, if your tires are hard enuff to do that, you really really need new tires.
jbeane is offline
Old 01-03-2011, 09:00 PM
Suspended
stock proline flatirons.
FTSC10 is offline
