Go Back  R/C Tech Forums > General Forums > Crawler Room
Brand new AXIAL XR 10 >
Old 05-10-2010, 01:42 PM
cliffhanger's Avatar
Default Brand new AXIAL XR 10
WOW that is so slick this will fly through the rocks Grin Grin Axial 1/10 XR10 4WD Competition Rock Crawler Kit Price at $456.99 USD
XR10™ FEATURES/SPECS
* Complete “no-compromise” competition ready kit
* All new front and rear specific strong durable composite plastic, lightweight axles.
o Low profile axle housing design for maximum ground clearance.
o Front steering axle with the ability to rotate (clock) the motor up/down.
o Rear axle is 16mm narrower than the front axle to squeeze through tight gate layouts.
* All New Behind the Axle (BTA) Steering *pat. pend.
o Enclosed steering slide with turnbuckles to adjust toe in and toe out.
o 8 kingpin angle helps keep scrub radius to a minimum, which equals less stress on your steering servo.
o Durable composite plastic - strong double shear knuckle arms with replaceable aluminum draw link mount.
o Splined adjustable c-hubs provide caster adjustments in 15 increments.
* Oversized Universals
o Oversized 12.5mm universals with 4mm and 2.5mm cross pins.
o Made of hardened steel
o No backlash like dogbone setups
o 45 of steering out of the box
* 37.9:1 gear ratio using the included 14T pinion. Gearbox allows for use of 12-19T pinions for gear ratios ranging from 44.2:1 through 27.9:1.
* Dual motors allow you to easily adjust your front and rear gear ratios independently.
* Compact and lightweight gearboxes keep the motor positioned closer to the axle housing and above the axle centerline for extra clearance.
* Aluminum chassis plates with durable composite plastic skid plate.
* Chassis provides multiple upper link adjustment holes for suspension tuning and adjusting anti-squat.
* Adjustable upper shock mounts included for fine tuning ride height and can be catered to your own personal driving style.
* Adjustable body mounts provide finite adjustments for different angles and heights.
* Removable electronics tray for easy maintenance and installation
* Waterproof receiver box with wire routing guides for cleaner electronic routing/configuration.
* Multiple ESC mounting plates and configurations
* Low profile battery mount places the weight of the battery at a lower position in the vehicle to help lower the center of gravity.
* Oversized rod ends with large 7mm aluminum links and durable composite plastic sleeves (replaceable).
* Light durable composite plastic upper links also aid in lowering the center of gravity.
* Full ball bearings (oversized differential bearings)
* Differentials: locked (spool)
* Wheels: New Axial 2.2 Competition Beadlocks
o Includes CNC orange anodized rings.
o Compatible with Vanquish patented wheel weight systems (Licensed by Vanquish Products)
o Minimal beadlock hardware for assembly ease
o Narrow offset to increase steering response and strength
* Suspension: 4-link, double triangulated
* 72-103mm shocks: includes aluminum bodies and 10mm machined Delrin pistons.
* Axial Hardline Body
o Competition inspired body – design, layout, and size all catered for optimum performance.
o Meets all U.S.R.C.C.A minimum requirements
o Dove-tailed front and rear to minimize interference with tires.
o Rounded roof line and cab forward design to improve roll-over recovery.
XR10™ Measurements
* Wheelbase: 317.5mm (12.5”) Max
* Front Wheel to Wheel (outside) Width: 260mm (10.20”)
* Rear Wheel to Wheel (outside) Width: 241mm (9.50”)
* Height: 5.25”-6.75” (133mm-172mm)
* Ground Clearance: 1.75”-3.40” (44.5mm-86.5mm)
*Note: The height and ground clearance were measured with Pro-Line Chisels and memory foams with no weight added to the wheels.
Hardline Body Measurements
* Length: 324mm (12.75”)
* Width: 134mm (5.25”)
* Height: 89mm (3.5”)
Required
* Radio: 2, 3, 4 Channel
* Servos: 1 (Standard Size)
* Speed Control: single or dual
* Motors: Dual 540 sized motors
* Battery : Compact LiPo, 2/3a, LiFe packs (Maximum size 30mmx25mmx90mm)
* Tires: Your choice of 2.2 tires and foams
Option Parts (available soon)
* Full line of aluminum and carbon fiber hop-ups
* Wheel Weights *Patent Pending
* Rear Cutting Brakes *Patent Pending
cliffhanger is offline
Old 05-10-2010, 02:29 PM
That is bad ass.
ADAN is offline
Old 05-10-2010, 02:46 PM
Company Representative
JoeNolasco's Avatar
Hey guys, check out the RPP Hobby vendor forum here on RCTECH for preorder info!
RPP Hobby Vendor Forum
These trucks look sick! Can't wait for them to get here!
JoeNolasco is offline
Old 05-11-2010, 10:19 AM
el_Fernando's Avatar
That body leaves alot to be desired. I'm not much into scale stuff but that thing looks like a UFO. I bet that rig will look great as a tuber. Some nice CF plates all around
On another note is this the only thing they are releasing? I was almost certain they would announce multiple rigs.
el_Fernando is offline
Old 05-11-2010, 10:33 AM
blue.coupe's Avatar
From their Axial countdown ad, I really thought they would be bringing something to race with?
blue.coupe is offline
Old 05-11-2010, 11:37 AM
Zach@4SEASONS's Avatar
Shoot, they brought something to DOMINATE the crawling world, thats pretty big right there!
Zach@4SEASONS is offline
Old 05-11-2010, 04:29 PM
Bleh! That body is ugly as sin. I too was hoping Axial had been hyping something other than a crawler. But I guess if your strictly into comp crawling and could care less what your rig looks like, just as long as it performs, then they will sell like hotcakes. And definitely appears with the list of goodies that it will be competitive.
Personally, I'll stick with my scaler, much more fun in my opinion.
Ferenczy36 is offline
Old 05-15-2010, 06:50 PM
drebies_one's Avatar
yea i think the body looks cool and im glad that axial is not straying too much off the beaten path....that is not the price my lhs is getting this truck for me....over 4hundo....no way heh.
drebies_one is offline
Old 05-16-2010, 04:02 AM
positronic's Avatar
I like the body, but then it's a comp body its about functionality. It's a very innovative rig, pity we have to wait 3 months for it.
they are under 300 bones in most stores that have them up for preorder
positronic is offline
Old 05-16-2010, 11:07 AM
860Crawler's Avatar
Its going to be pretty kick ass
860Crawler is offline
Old 05-16-2010, 10:47 PM
transambill's Avatar
I have one on preorder at Tower (est late July). There $299.99 and with my super saver discount I'm getting it for around 240 shipped.
I have 2 scalers and a tuber. This will be my first MOA comp crawler.
I personally like the body. I guess cause it's different but agree it would be kick a$$ with that body and an exo cage.
transambill is offline
Old 05-17-2010, 12:59 PM
i didnt realize it was about 3 months out to get....good it will give me time to save the money....duel brushless set up....i have an integy irock....moa and it is junk,i cant wait for this truck.
question is there any dual brushless esc....i cant recall anyone making one
if not somebody should make one....
maybe kershaw..i think they just released a 1/6 scale brushless....
and then put that on the killer crawler from rc4wd....and have your wife divorce you for spending over a thousand on a huge crawler...haha
wow i went way off topic sorry.
Old 06-15-2010, 07:30 AM
If this is any thing like the AX-10 Axial will have a hit on their hands. It looks like a lot of R&D went into this and the factory support will be great ( it has been with all of the Axial stuff I have used in the past). I understand there might be a few of these run by factory guys ? at the Axial WCC next week. This is right in my backyard cant wait.
TheOtherBill is offline
Old 06-15-2010, 08:57 AM
i wish that was in my back yard
Old 06-15-2010, 09:45 AM
positronic's Avatar
yeah I think heard they will be there, take a camera!
I dont know of a dual brushless esc, might have to run 2 esc's if your dead set on brushless (id be going that route if I had radio with enough channels)
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
