Losi MRC shocks
I need a crash course in travel limiting. I just bought my second losi MRC and this will be the first crawler I have modded. So far I have moved the receiver bottom side, weighted the wheels, installed 30deg. bent links, lowered & trimmed the body, and put on a set of losi alu. threaded shocks.
I still have to flip the trans and order a couple of 2-cell Lipos. And I ordered a set of Pro-Line flat irons today.
My problem is the crawler worked better with the stock shocks, I know that I just need to experiment with it but I really don't know how. Everyone talks about needing to limit the droop or tuck but I have never had the need to, there for do not know how.
The specific problem I have is with the dampening of the shocks they are VERY stiff to be on such a light rig and it doesn't want to flex because of it(or so it seems) If that is the case what wt. oil should I run or will that help? Any advise will help.
Thanks-Chase
Thanks-Chase
Thanks-Chase
Thanks-Chase
The amount of travel you need and the weight of oil to use depend on the person and the terrain. RCCrawler has a ton of information on Losi MRC setups.
