Go Back  R/C Tech Forums > General Forums > Crawler Room
Help setting up a Traxxas system. >
Old 12-05-2022, 07:17 PM
Default Help setting up a Traxxas system.
I have a Traxxas TRX-4 Bronco. I want to install the Traxxas Front/Rear Locking Differential and a Traxxas 8196 TRX-4 Two Speed Conversion Kit. The problem is do not understand how they get all this to work with their 4 channel radio. It would seem there is 5 channels needed.
Any help understanding this Please
chuck732 is offline
Old 12-05-2022, 08:32 PM
Trader Rating: 15 (100%+)
The front and rear locker servos are on a splitter to one channel in the RX. The both work off the 3 position toggle on the top of the TX. Check to make sure your RX is the correct one.
rotomoto is offline
Old 12-18-2022, 11:30 PM
Makarrov's Avatar
The RTR uses a 5 channel radio and a 3 position toggle for the diffs. You can just combine the diffs on one channel if you have a 4 channel.
Makarrov is offline
