Go Back  R/C Tech Forums > General Forums > Crawler Room
cheap INJORA LCG Carbon Fiber Chassis now also to TRX4 >
Old 11-12-2022, 12:58 PM
Suspended
Default cheap INJORA LCG Carbon Fiber Chassis now also to TRX4
I did check new items at Injora website.
Now they have also the LCG Carbon chassis kit to TRX4 cheap.
The Axial II is sold by Powerhobby . I believe you can also find this at Powerhobby now or soon
If anyone will buy and mount this LCG Kit please give a Review how you like it.
INJORA 313/324mm Wheelbase LCG Carbon Fiber Chassis Kit Frame Girder for 1/10 RC Crawler TRX4 Upgrade Parts
In Stock
SKU: TRX4-005Regular price$61.99
Suit for 1/10 Scale RC Crawler TRX4
Features:
  • Rails are made of high-quality carbon fiber.
  • It adds many shock mounting points for better suspension tuning.
  • The 5 design allows for a lower center of gravity.
  • Comes with 313mm and 324mm wheelbase links for easy DIY and assembly
  • Compatible with TRX4 stock Axles, Transmission, Drive Shafts, Shocks
  • Change the layout of the car, create stronger climbing abilit
Specifications:
  • Girder Material: Carbon Fiber
  • Links Material: Stainless Steel
  • Total Weight: approx 490g (14.28oz)
  • Length: 416mm (16.38in)
  • Width: 78mm (3.07in)
EQUIPMENT NEEDED (not included):
ESC, Servo, Motor, Radio Control, Battery, Axles, Shock, Transmission, Drive Shaft
Package List:
1 * Set 1/10 RC Crawler LCG Chassis Kit
I will do two Scratch Builds.
Buy both Axial and this TRX4 carbon LCG Chassis kits.
I know what parts to use for the Axial.
I Wonder what transmission i need to this TRX4 LCG chassis ?
Is there any cheap aftermarket complete TRX4 Transmission ?
I have found one cheap in metal with open gears.
I dont like open gears !!
I like to have one with covering case, closed gears
flymetonight is offline
