Go Back  R/C Tech Forums > General Forums > Crawler Room
How many Hours will the  Vanquish VS4-10 Phoenix Straight Axle take 2 build(beginner) >
Like Tree1Likes
  • 1 Post By the rc guy
Old 11-08-2022, 10:53 AM
Suspended
Default How many Hours will the Vanquish VS4-10 Phoenix Straight Axle take 2 build(beginner)
Aprox, How many hours will the Kit take to build for Beginner in Crawler Kits.
I have only build couple Bashers. Buggies and Monsters before.
Just the kit.
Less or more than 10hours ?
Wheels and Body (paint) you dont need count in
flymetonight is offline
Old 11-09-2022, 01:43 AM
FREEDOM83's Avatar
i dont mount any phoenix but mount 3 vs4 pro , chasis only , with electronics , for beginner ... maybe 8 hours easily
FREEDOM83 is offline
Old 11-09-2022, 04:58 AM
the rc guy's Avatar
give yourself the time to do it.I donr know your skill level and you dont say how long it took you b4 on builds.
the rc guy is offline
Old 11-10-2022, 10:35 AM
R/C Tech Elite Member
mrreet2001's Avatar
If you can't read through the manual and get an estimated time to build ... we probably can't guess how long it will take you either.
mrreet2001 is offline
Old 11-10-2022, 01:45 PM
Suspended
Thank you. FREEDOM83
Im just thinking how many days it will take if i do 2h day.
One told me these kits are easy build in 3-4h HEHE.
I need plan this can take me 10h atleast, 12-14h
So 1 week aprox / 2h day
Will the Fusion Pro 2300kv Two in One Combo fit this standart VS4 ?
https://www.vanquishproducts.com/vs4...bundle-portal/
Builders bundle without wheels and body.
This is a cheap Slider build kit
I will buy Proline Cliffhanger body to this.
Old 11-14-2022, 06:00 AM
Sir 51D3WAYS's Avatar
^That motor should fit. Also, the transmission on these is quite complex, so budget atleast a week, probably 10 days, working flat out.
Sir 51D3WAYS is offline
Old 11-14-2022, 10:09 AM
the rc guy's Avatar
the last 2 n 1 combo I used had nearly no brakes hope the fixed that issue
flymetonight likes this.
Old 11-14-2022, 11:22 AM
Suspended
Yes this V2 is ALOT Better, actually the best combo out there less than 200$ many Professional says.
I love it. Super strong Handbrake. The V1 is not good sadly. This V2 is superb
Hobbywing Fusion Pro 2300kv Review - Best brushless rc crawler motor/esc combo ?
https://www.youtube.com/watch?v=v0f7...annel=RCReview
edit hmmm sorry for that large text, i can not edit it to smaller either This forum has no text size funktions
Old 11-14-2022, 11:26 AM
Suspended
Will 20kg Servo be enough to the DIG funktion ? I have one Brand new 20kg waterproof Servo i have no use for . You can change the DIG on the run in this rig. So it needs to be stronger than normal DIG rigs i know.
20kg should do it ?
