Go Back  R/C Tech Forums > General Forums > Crawler Room
M548 tracked vehicle >
Like Tree14Likes
Old 08-27-2022, 03:19 PM
  #31
Originally Posted by RogueIV
Incredible detail on this build!
Thanks!
These LEDs were a PITA to mount. When I did the rear section,didn't thought in practicability to mount lights. But was doable:
It's a printed taillight with a real piece of stoplight inside
And this:
You guys don't imagine for how long I've waited for that extra bit of patience to fit the weatherstripping in the windows and then, the wipers
first 3 are done
RogueIV likes this.
cooper_xl is offline
Old 08-29-2022, 04:15 PM
  #32
The henglong gearboxes are not up to the task.I'm already on the second set.
Working on new system using these gearboxes:
Ordered a 30:1 to test
Thought of machining the structure but 3d printing could do the job
First of all, I'll not say that this was my original creation
There's a german shop( https://www.modellspiegel.com/) who created and sells these gearboxes for 1/16 tanks:
I had several ideas for the new drivetrain and the chosen was heavily influenced by this layout above
But I the time, I'm not in condition of forking out all that money and also like to do things myself as much as possible
To the build,this is where it sits now:
Need to do a test trial to see if the ratio it's good or not, and then order the other gearbox
RogueIV likes this.
Old 08-30-2022, 02:28 PM
  #33
First trial of the setup on 3s. It's so good when things work at first try. Unfortunately, the gearbox it's too fast(33:1,actually), I've already ordered a slower one. The only bad thing was that the bores on the gears are a bit off center, that's why it sounds that way
RogueIV likes this.
Old 08-31-2022, 05:19 PM
  #34
Now with slower gearboxes(56:1),everything assembled, even correcting the pinion bores that were off-center(the reason of the noise in the last video)
Old 09-01-2022, 12:04 PM
  #35
there it is,assembled and working. Just need a cover to reduce some noise and prevent that some LED wires don't get caught on the gears. The electronics are not in place because I'm about to take everything out to paint the hull
There's some video.Sorry about the background but I can't go to the woods right now
RogueIV likes this.
Old 09-04-2022, 02:20 PM
  #36
My goal of closing off the drivetrain it's closer to finish.Needed something on top to keep away dirt and sand
And a small rubber lip on the cover to keep sand and dirt away
First idea was a standard cover but started to mess with the 3d printer and decided to do a more elaborate clear cover to see the gears working(might sound like a joke but many non-rc people who see this truck don't understand how this truck moves or why it needs 2 motors...)
RogueIV likes this.
Old 09-05-2022, 02:33 PM
  #37
Now a small detail that it's almost invisible but wanted to do it anyway
Each road wheel arm has a piece atached to the hull where the axle pivots
So printed 8 of these:
OD paint to cover it all
These were meant to be bolted on but will try with glue only, for now
Old 09-06-2022, 02:52 PM
  #38
The M548 often came with the winch to load cargo,mainly ammo
I thought mine would look more complete with it so...3D printed the I-beam and the winch:
It's held in place with small zip-ties:
It has a chain, only needs a hook or a D-ring
RogueIV likes this.
Old 09-11-2022, 05:21 AM
  #39
Dollhouse stuff:
Thought that the operator needed some goggles for his helmet. The first idea was to scratchbuild everything but my Dremel broke so I've copied the goggles' frame from a real army model and 3d printed it.The lens are from a bit of clear package plastic and the strap is a strip of bicycle inner tube
And a set of binoculars to spot other fellow truckers
The binoculars are printed, the strap is a strip of rubber and for the lenses, I put a drop of green threadlock in place(designed those parts like small cups)
RogueIV likes this.
Old 09-14-2022, 06:23 PM
  #40
Final details:
One is a set of tags and labels, like this one:
Through social media,came to know a soldier who works on the base where all our M548s are. He gladly helped by taking photos of their tags and labels that I've remake in vector to allow proper resizing. Then they were professionally printed and all the text is clear!
The other one came to mind a couple days ago. The seat cushions I've had were fine. Cloth with foam inside, just don't look very scale
So, took some modelling clay, did a mold to have a uniform thickness , the texture was made pressing cloth to the clay and the stitching was with a spatula. Roughed them up a bit and the next day, applied Tamiya XF-62
RogueIV likes this.
Old 09-17-2022, 03:08 PM
  #41
Life's full of sacrifices like take a new truck to a beach to see how it handles:
elk, smirkracing and RogueIV like this.
Old 11-17-2022, 06:36 AM
  #42
Took the chance of letting the M548 out and visit the beach
https://youtu.be/FaNbwXddJ5Q
