Go Back  R/C Tech Forums > General Forums > Crawler Room
I finally pulled the trigger TRX-6 !! >
Like Tree1Likes
  • 1 Post By xfbaap
Old 12-09-2021, 08:57 PM
Default I finally pulled the trigger TRX-6 !!
I turned it on for about 5 minutes. This thing is awesome..
i gotta shop for parts..
jeanethics is offline
Old 12-13-2021, 10:42 AM
fyrstormer's Avatar
You finally pulled the trigger...and the truck started moving forward? 😋 That's what it's supposed to do, anyway.
I recommend Samix black-powdercoated brass portal gearbox housings for all 6 wheels (extra weight down low), a front overdrive diff gear (it really helps with the TRX-6's very long chassis), and whatever steel center driveshafts you can find. You might need to cut one shorter to fit the tiny space between the 2nd and 3rd axles.
Also, the TRX-6 has trouble climbing over sharp obstacles like curbs because its chassis is so long. Rebuilding the 2nd-axle differential with Tamiya Anti-Wear Grease (insanely thick and sticky silicone grease) gives it a very strong limited-slip action and helps with that problem without needing to lock the diffs constantly. (I believe the point of having locking diffs is to be able to leave them unlocked most of the time, and only lock them when you get into the really hairy stuff. curbs don't count as "really hairy stuff".) The 1st and 3rd axle diffs don't need to be rebuilt with super-sticky grease, just the 2nd axle diff.
fyrstormer is offline
Old 12-19-2021, 10:28 PM
Lol.. trigger pulled Forward action!!
fyrstormer Thank you, will order the housings ASAP.. Thank you for the tips.
Iíve been working so much havenít had time to play. The little drive I have had with it makes me like it a lot. I have it bone stock.
going to start adding stuff to it now. See what I can get shipped!!!
Old 02-18-2022, 05:43 PM
xfbaap's Avatar
Awesome crawler! I love my trx6, probably my favourite crawler of all time 🤘
hotrodchevy14 likes this.
xfbaap is offline
