Go Back  R/C Tech Forums > General Forums > Crawler Room
Element RC Enduro >
Element RC Enduro
Like Tree7Likes
  • 3 Post By Rock Concepts
  • 1 Post By soze
  • 2 Post By Cesco
  • 1 Post By anthonyscardina
Element RC Enduro
Old 07-10-2019, 11:56 AM
Default Element RC Enduro
New from Associated Electronics- Element Enduro
Rock Concepts is offline
Old 07-10-2019, 11:59 AM
Features
  • CMS (Chassis Mounted Servo)
  • Adjustable front track bar
  • Universal front drive axles
  • Stamped steel frame rails
  • Enclosed receiver box
  • 12mm wheel hexes
  • Adjustable front and rear bumper mounts
  • Adjustable width rock sliders
  • Two battery boxes
  • Aluminum motor plate
  • Adjustable body posts
  • Optimized ball cups for more fluid axle articulation
  • Adjustable rear shock mount positions
  • Telescopic driveshafts front and rear
  • Extruded aluminum driveshaft splines
  • One-piece rear axle design
  • Splined front axle with adjustable caster
  • Machined input pinion gear
  • Metal ring gear
  • Machined steel top shaft
  • Metal idler gears
  • Heavy duty 5mm diameter steel links
  • Metal ball bearings included
Old 07-12-2019, 02:45 AM
Cesco's Avatar
Looks like a nice addition to the crawler/scaler market.
Cesco is offline
Old 07-17-2019, 10:06 AM
I'm pretty happy with it so far. It's a good platform.
Rock Concepts likes this.
soze is offline
Old 07-20-2019, 04:19 PM
Cesco's Avatar
I bought one. I like it a lot.
Rock Concepts and soze like this.
Cesco is offline
Old 07-26-2019, 01:43 PM
DriftMatt's Avatar
Great new release, I'm holding out for the kit version personally, was so stoked to see this when they released it, finally something "fresh" in the crawler world, The OD gearbox will be awesome fun to mess with, the BTA setup is a great touch and knowing AE and shocks... Well I dare say no upgrade will be needed in that department 😆.
But the best part of the sendaro would have to be the DIY number plate stickers 😁😁 What an Awesome Release 😎
DriftMatt is offline
Old 09-30-2019, 09:41 PM
Kjp616's Avatar
Default Great Crawler out of the gate.
Great rtr Crawler all around, however having built an ran both the rtr and kit, the kit is the better of the two IMO
Great job Associated!
Kjp616 is offline
Old 10-01-2019, 07:11 AM
Built the kit about a month ago, great truck, the overdrive is awesome! I was going to make it a small tire build but couldn't lower it as much as I wanted, and the shocks are so nice I didn't want to go leaf spring on it. Here's a pic at the local spot, a Hobbytown USA 5 minutes from the house.
cavwrench likes this.
anthonyscardina is offline
Old 10-05-2019, 09:12 AM
Kjp616's Avatar
Nice looking rig, I have the exact same rims on my TRX4.
Kjp616 is offline
