Body size
Old 07-03-2019, 01:39 PM
2stroketim's Avatar
Default Body size
Ok - maybe this will garner more responses....
Is there a difference in the body post lengths as it relates to wheelbase?
Or are all clear bodies basically the same, and you ream the body post holes accordingly?
For example - I want to replace the body on my Ascender Suburban with a Jeep body. Will I have issues with mounting? My assumption is that the wheel base of the rig determines the size of the body, because the wheel wells are all a little different.
If my assumption is correct, how to I go about determining what my wheelbase is? Because my rig has an adjustable wheelbase, how do I know what it is?
2stroketim is offline
Old 07-03-2019, 11:27 PM
sugs's Avatar
Get out your tape measure and measure the distance between front and rear axles. That's it.
sugs is offline
