Like Tree5Likes
  • 1 Post By sugs
  • 1 Post By the rc guy
  • 1 Post By sugs
  • 1 Post By OverGeared
  • 1 Post By DRTMI
Battery
Old 04-10-2019, 06:52 PM
Default Battery
Need help on where to buy these? Thanks
bring it on is offline
Old 04-10-2019, 08:33 PM
sugs's Avatar
Could be very challenging to find that configuration, may have to make it yourself. You can search google for "sub C NiMH battery" to get places to buy individuals. Or search "7 cell NiMH battery" to get ready made packs. I did a quick search but didn't find any that were configured exactly like yours.
bring it on likes this.
sugs is offline
Old 04-11-2019, 12:18 PM
the rc guy's Avatar
a 7 cell nimh saddle pack will be hard to find as said above best to make it yourself..
the rc guy is offline
Old 04-11-2019, 06:05 PM
Need help, my buddy wants to go lipo so what are you guys using and will it fit where these where?
Old 04-11-2019, 06:06 PM
Old 04-12-2019, 12:05 AM
sugs's Avatar
I would look for a 2S lipo pack made for racing quadcopters. You should be able to find some that are more "square", which looks like what you need.
sugs is offline
Old 04-23-2019, 07:42 PM
1spunspur's Avatar
Looks like heck to me. Is there some reason why you can't use an ordinary 2 cell Lipo in the ordinary 6 pack configuration.?
1spunspur is offline
Old 04-30-2019, 06:43 PM
1spunspur's Avatar
Taking a longer look at your pics, I would have to ask if you considered using saddle packs that are commonly used in on road pan cars. My saddle packs are approx. 70mm long x 46mm wide x 18mm wide. 3200 mah. larger mah sizes are available.
Old 04-30-2019, 07:50 PM
R/C Tech Elite Member
Trader Rating: 71 (100%+)
Your best bet would be over at rccrawler.com the comp guys would prob be able to help you better
freaksofnature is offline
Old 05-01-2019, 07:05 AM
OverGeared's Avatar
Trader Rating: 15 (100%+)
Can't find a same 7-cell NiMh saddle pack configuration.
MaxAmps carries 6-cell and 8-cell NiMh saddle packs designed for mounting on crawler axles specifically.
You might want to check the voltage requirement on the ESC and receiver if it can handle the 8-cell, the 6-cell should be fine but with a little less power punch as compared to the 7-cell.
Hope this helps.
6-cell saddle pack
8-cell saddle pack
OverGeared is offline
Old 05-01-2019, 08:16 AM
Super Moderator
DRTMI's Avatar
Trader Rating: 27 (100%+)
A 1300 mAh 2s should fit there without any problems.
DRTMI is offline
