Go Back  R/C Tech Forums > General Forums > Crawler Room
Soze rejoices the Traxxas TRX4 Sport Kit >
Like Tree4Likes
Old 03-28-2019, 01:06 AM
Default Soze rejoices the Traxxas TRX4 Sport Kit
Traxxas.... Kit.... Two things that I never thought would go together again since the 80's. Yes, they did come out with that chassis kit with all the electronic doo-dads that I didn't want... so I passed on it. They came out with a TRX4 Sport which is exactly what I wanted from the platform, but no kit was in sight, so I bought the RTR. Lo and behold... The day finally came where Traxxas released what I think a lot of others besides myself were clamoring for. Insta-buy.
My build is going to start out pretty much stock at first, and maybe deviate a little once I tie-up my multi-other projects that I'm working on. I think I bit off more than I could chew grabbing most of the other base platforms out there from other manufacturers at the same time.
Let's begin...
Build Details
Kit:
Traxxas TRX4 Sport Kit (ebay)
Parts:
1.9" Alloy Beadlock Wheels (ebay)
Traxxas 8080 Inner Fenders (ebay)
Traxxas 8053 45T Spur Gear (ebay)
Robinson Racing 12T 32P Pinion (ebay)
Slipper Pads from Traxxas 8254 Slipper Clutch Rebuild Kit (ebay)
TRX4 Aluminum Motor Mount (ebay)
Adjustable Shock Mount C-Hubs
Adjustable Shock Mount Rear Hubs
Metal Inner Portal Knuckles
Electronics:
Turnigy MG959 V2 Servo (eBay)
Holmes Hobbies Trailmaster Sport 550 21T Brushed motor (eBay)
FlySky GR3E 2.4GHz 3-Channel Receiver (eBay)
FlySky GT-3C 2.4 GHz Radio (eBay)
HobbyWing Quicrun WP-1080 Esc (ebay)
HobbyStar 3S 3700mah LiPo (ebay)
Tools:
Versachem Brake Caliper Grease (ebay)
Permatex Anti Seize Lubricant (ebay)
Tamiya Side Cutter (ebay)
Protek RC Shock Pliers (eBay)
DEWALT DCF610S2R 12V MAX Cordless Lithium-Ion 1/4 in. Hex Chuck Screwdriver Kit (ebay)
MIP Metric Speed Tip Set MIP9512 (ebay)
Associated 1656 FT 1/4 in Driver Handle (ebay)
Duratrax Shock stand (ebay)
Bob Smith Industries Blue Thread locker (eBay)
Multistar Rubber R/C Work mat
Paint:
Tamiya PS-5 Black (ebay)
Tamiya PS-30 Brilliant Blue (ebay)
Tamiya PS-23 Gunmetal (ebay)
Tamiya PS-55 Flat Clear (ebay)
Plasti-Dip (ebay)
Tamiya 5mm Masking tape for Curves (ebay)
Frog Tape (for general masking) (ebay)
soze is offline
Old 03-28-2019, 01:07 AM
Section A: Transmission Assembly
We start off with the transmission. Section A.
Here is the parts bag for Section A.
Step A1 Parts
Step A1 complete
Step A2 parts
Step A2 complete
Step A3 parts
Step A3 complete
Parts for Step A4
Step A4 complete
Step A5 parts
Step A5 complete
Step A6 parts
Step A6 complete
Step A7 parts
Step A7 completed
And that's all for the "Transmission Assembly" - Section A
soze is offline
Old 03-28-2019, 01:39 PM
Section B: Rear Axle Assembly
Yay, we move on to the axles!
You need this rear axle parts bag.
You also need the spool bag.
Step B1 Parts
Step B1 Complete
Step B2 parts
I think some have had issues with getting the diff plugs go though easily, but it didn't seem to be an issue on my build at all.
The e-clips on the other hand.... yeah we all know by now that I hate e-clips.
Step B2 complete
Parts for Step B3
You need to be very careful with the ball bearing sizes used in this step. The 5x11x4mm bearing is shown with blue shield in the instructions, but in reality it's black. So carefully measure the bearing sizes, or just match it up with the instructions since it's 1:1 scale.
Step B3 complete
Parts for Step B4
Step B4 complete. Make sure to not overtighten the diff cover.
Parts for Step B5
What I liked about the parts for this step is that the parts clearly had identifying markers for which part goes on the left and right. Nothing left up to vagueness.
Step B5 complete.
Parts for Step B6
Again, with this step, you need to carefully match up the ball bearing sizes. The 6x12x4mm is shown with blue shield in the instruction manual, but they are all black shielded. Measure carefully, or match up carefully with 1:1 illustration in the instruction manual.
Step B6 complete
Parts for Step B7
Step B7 complete. In the picture it looks like I used too much grease, but that's not the amount that it actually ended up with. What I usually do is pack the grease on thick, close up the assembly and give it a good few rotations to spread the grease out, then remove the excess. Didn't bother to or rather forgot to another picture post excess removal though.
Parts for Step B8
Step B8 complete. Be sure not to over-tighten the screws in this step.
Step B9 parts
Step B9 complete
Parts for Step B10
No need for fiddly pins that fall out of the hexes! Thank you Traxxas! Was nice that this kit comes with metal wheel hexes and locking screw pins.
Step B10 complete
And... we're done with Section B - Rear Axle Assembly.
soze is offline
Section C: Front Axle Assembly
You'll need the front axle parts bag.
Steps C1- C4 are pretty much the same as the rear axle assembly steps B1-B4, so I'll skip over those.
Parts for Step C5
Step C5 complete
Step C6 is the same as rear axle Step B6
Parts for Step C7
Also trying out/starting to use Permatex anti-seize on my CVD/Universal joints.
You can put on a little of it, and it spreads really easily and evenly with a few rotations.
Versachem grease on the gears
Step C7 complete
Parts for Step C8
Step C8 complete
Step C9 is basically the same as rear axle Step B10 except one of the link mounts is now a link mount + panhard mount.
And now we're done with Section C - Front Axle Assembly.
We now have a set of TRX4 Sport axles!
soze is offline
Section D: Chassis Assembly
Can start to see the build coming together now.
Here is the parts bag that you'll need.
You'll need these for Step D1
Step D1 complete
Parts for Step D2
Once again, it's nice that Traxxas clearly marked pieces with FR, FL, RR, RL so that there is no confusion which brackets go where.
Step D2 complete
Step D3 parts
Step D3 complete
Parts for Step D4
Step D4 complete
Parts for Step D5
Step D5 complete
Parts for Step D6
Step D6 complete
Parts for Step D7 - you'll notice one 3x10mm is missing. It was missing from my parts bag, but I had a spare one from my parts bins.
Step D7 complete
That's all for Section D: Chassis Assembly
soze is offline
Old 03-28-2019, 03:13 PM
Section E: Electronics Installation
So as far as electronics go, I'll be using the following:
You'll need the electronics parts bag for this section
Step E1 Parts
Step E1 complete. Fits like a glove.
Step E2 parts
You'll notice that I'm using the stock 17T pinion, and the stock 39T spur from the earlier transmission step. I'm building it as is initially as I'm using the Holmes Hobbies 21T 550 motor instead of the Traxxas 21T Titan Reverse 550. I've already purchased the 45T spur + pads and 12T/13T pinions to be used later.
Using a Holmes Hobbies 550 21T Trailmaster Sport. I really should swap to using bullet plugs, but I've got a bunch of Tamiya style connectors in my parts... and it just makes sense to use them.
So the Holmes Hobbies motor shaft is shorter than a Traxxas Titan motor shaft, so I had to mount the pinion the opposite way from what the instructions wanted.
With the stock 17T pinion + 39T spur, we'll be using the "C" mounting hole on the motor mount. I might look into updating this part later on.
Step E2 complete
Parts for Step E3
Step E3 complete. Using a FlySky GR3E receiver so there were a few challenges in regards to the length of antenna, receiver wire lengths, etc.
Step E4 parts
Using a Turnigy MG959v2 servo that I had on hand for now.
Step E4 complete
Step E5 had two 3x12mm screws used for mounting the Traxxas esc. I'm using a Hobbywing Quicrun WP1080, so those weren't needed.
Step E6 parts
Step E6 complete. You can see I rotated my receiver around. I did it to accomodate wire lengths. I'm still playing around with it to see if I can get the receiver light to line up with the receiver light window on the case.
Step E7 Parts
Step E8 is basically routing the wires to the receiver and securing them with the included zip ties. I had to create 2 wire extensions as neither the servo nor the esc wire was long enough to reach the inside of the box comfortably. It looks like I'll have to create 2 more longer ones so that I can turn the receiver around to the other orientation and hopefully line up the light to the light case light window.
Parts for Step E9
You need to grease the foam seal on the receiver box outlet
Receiver box o-ring in place
Step E9 completed. Receiver box all closed up.
Parts for step E10
Step E10 completed. I have a feeling this is going to be coming off eventually for a 3D printed low center of gravity tray in the future.
Parts for step E11. Metal servo horn included!
Step E11 complete
That completes Section E - Electronics Assembly!
soze is offline
Old 03-29-2019, 01:52 AM
targetingxmod's Avatar
Nice!
I will have that RC in a near future either with my Range Rover 2 door body or the Patrol Y61 body! :P
Thanks for sharing. When have it, i will look at these follow ups!
targetingxmod is offline
Old 04-03-2019, 12:29 AM
Section F: Suspension & Driveline
It's continuing to come together!
This part of the build requires these bags.
Step F1 uses these pre-built shocks. {commercial voice}Just add oil!{/commercial voice}
The only thing you need to assemble in this step is the oil nozzle for the shock oil bottle.
Getting ready to do some oil filling with my trusty ProTek RC Shock Pliers...
Step F1 complete....Doh! I forgot to take finished shock pictures... It's ok, you'll get to see them later.
Time to move onto the links with this bag... with the pre-assembled links...
Step F2 Parts
F2 complete
Step F3 parts...
Step F3 complete
Lining up the proper links for step F4
Also need these screws
Step F4 Complete
Step F5 parts
F5 complete
What we need for step F6
F6 complete.
Screws needed for Step F7
F7 complete
Final bag we need for this section
Step F8 parts
RED ALERT! One of the output drives is defective with the slots cut at an angle instead of straight up and down. This caused the driveshaft to bind.
Called up Traxxas.
me - "Hey, um... I just bought a TRX4 Sport kit, and one of the parts is defective."
Traxxas - "what part is it, and what's the part number?"
me - "It's the output drive that you can find in part# 8295"
Traxxas - "what's your name and address?"
me - "My name is #####, and my address is #####..."
Traxxas - "ok we'll send one out to you right away"
me - "That's it?"
Traxxas - "That's it!"
Few days later this showed up in the mailbox. Back in business!
Old on left, new on the right.
Due to technical difficulties... Step F8 took the longest, but it's now complete.
Parts for Step F9
Step F9 complete.
And with that we are complete with "Section F: Suspension & Driveline"
lagcisco likes this.
soze is offline
Old 04-15-2019, 05:02 PM
Section G: Final Chassis Assembly
Coming to the home stretch of this build!
These are the parts for Step G1.
Pay attention to the rotation direction for the tires as they are directional. I will not be gluing on the tires and using the wheels even though I think they look decent, because I much prefer using beadlock wheels. I'm going to give these tires a shot first stock, and modded with siping/cutting.
For the rest of this section you will need the "Body Mounting Bag"
These are the parts for step G2
Step G2 complete. Crossmembers mounted on.
You need these parts for step G3
Make sure you pay attention to the direction of the posts.
Step G3 complete
These are the parts you need for step G4
So, I encountered my second issue with this kit. I was missing a 3x10 screw. At this point of the build, I should have 12 total 3x10mm BCS screws. I had 11. This is where Traxxas probably should give some extra hardware in case they miscount.
Putting together the front bumper assembly requires 2 3x10mm and 1 2.6x8mm. Luckily, I had an extra 3x10mm screw that I poached from my GMADE GOM box of parts.
Step G4 Complete.
You need these parts for step G5
Step G5 complete. Eagle eyes will notice that I have the sliders on the wrong sides. Not to worry, they have since been correctly put on the correct sides (left --> right & right --> left).
This completes "Section G: Final Chassis Assembly"!
soze is offline
Old 04-15-2019, 06:01 PM
Section H: Body Assembly
Let's wrap this build up in stock form and get this thread ready for upgrade and crawling updates.
So, the weather finally warmed up, and I got around to painting the body. I used the following for getting this body done.
Paint:
Tamiya PS-5 Black
Plasti-Dip
Masking:
Here's the end result for the body.
Here's the Tamiya 5mm Masking tape for Curves that I used.
Frog Tape for general masking duties.
You'll need these parts for Section H
These are the parts for Step H1
Step H1 complete
These are the parts for step H2.
I encountered my 3rd Issue with the kit. You'll notice that one 2.5x8mm screw is missing. I should have a total of 10, but I only had 9 left during this stage of the build. Again, wish there was some extra hardware to cover. Luckily, I was able to snag yet another screw from my parts for other trucks.
Step H2 complete
Here are the parts for Step H3
Eagle eyes will see in that picture above that I used the wrong 3x8mm FCS screws. There are actually 2 styles of 3x8mm screws with that big flat FCS head. One uses 2mm hex driver, the other uses 2.5mm. I will show the differences further below.
I also took this opportunity to add a little sharpie + paint marker detailing to the scale parts. Not a perfect job by any means, but good enough to not look like 1 color plastic bits.
Step H3 complete
Again, I used the wrong screws on these rotopacks
These are the parts you need for Step H4
Step H4 complete
You need these parts for Step H5
Step H5 complete (still the wrong screws on the rotopacks)
So getting the final step H6.... I discovered I used the wrong 3x8mm FCS screws for the rotopacks. There are two types of 3x8mm FCS screws included in the kit. One type uses 2mm hex drivers and the other 2.5mm hex drivers. The one with the bigger flat head and 2mm fitting is used for the rotopacks. The rest are for mounting the Expedition cage onto the body.
The top FCS screw is for the rotopacks.
The right screw is the correct one.
You'll need these parts for step H6
Step H6 complete
And that completes "Section H: Body assembly"!
The build in stock form is now complete!
soze is offline
Old 04-15-2019, 06:06 PM
You didn't think I forgot to give you guys the complete finished look did you?
I'll try to get some better pictures with better lighting up soon, but for now these will do.
Here's some pictures of it all finished up.
neospirit, duhjun and Steve8 like this.
soze is offline
Old 04-23-2019, 02:02 PM
rcguyfpr's Avatar
Trader Rating: 43 (100%+)
very nice truck. I like the add-on rack, but I really don't have the time to build. I may go for a RTR, and add the rack accessory.
rcguyfpr is offline
Old 04-25-2019, 09:59 AM
I was very intrigued when I saw this kit on Traxxas' website but I was a bit disappointed that it doesn't appear to come with lockable differentials and ability to switch gears. Have some questions about this if you have the time to answer Is there a work around to get this to work, without adding a tonne of expenses?
I haven't been doing a lot in RC since I started a year ago. As such I don't have a lot of experience but I'm now getting more involved again..
My favourite model currently is my Traxxas Summit (out of UDR, E-Revo 2.0, Arrma Senton 6s) and some more. Never thought it but I really like crawling most Great way to play with my nephew as well; nice and slow the Summit is.
If it is possible to get the remote locking differentials on this one, which motor/ESC would you use?
HelsRike is offline
Old 04-25-2019, 10:40 AM
If you get the RTR, You'd need to add the Rack accessory, and also the plastic molded front grille and rear tail light assembly. Otherwise you'll just have decals for the front grille & lights and the rear lights.
You can always buy the more expensive chassis kit (ebay link). That one comes with the lockable diffs, all the electronics required (servos, esc, transmitter, receiver, motor). It just doesn't come with a body.
To get the sport kit with lockable diffs, you'll have to buy the required servos + cables/parts etc. The Axles are capable of it, but just don't have all the parts.
If you really want the lockable diffs I think the chassis kit with all the electronics (ebay link) or one of the non-sport RTRs is the way to go.
soze is offline
Old 06-21-2019, 12:10 AM
These wheels might work?
soze is offline
