Go Back  R/C Tech Forums > General Forums > Crawler Room
My Axial Yeti 1/10 "Mod" >
Like Tree1Likes
Old 03-06-2019, 11:02 AM
targetingxmod's Avatar
Default My Axial Yeti 1/10 "Mod"
Yep...got myself a new to me RC!! (already with some upgrades)
-It got a brushless 4s 80A no name ESC and a 4300kv motor 3650 size! And some alloy parts installed!
Made a short run video that will post later!
Think i will use only on 2s... this ain't a speeder! We will see!
targetingxmod is offline
Old 03-06-2019, 01:54 PM
Old 03-16-2019, 03:30 PM
Old 03-16-2019, 03:37 PM
Old 03-24-2019, 12:26 PM
Put a spare tire...like it more! More "scale" :P
Old 03-24-2019, 12:29 PM
Old 03-31-2019, 03:25 PM
Old 04-06-2019, 01:06 PM
Old 04-26-2019, 10:35 AM
soze likes this.
Old 04-27-2019, 11:56 AM
One more beach video..
And after that...
Those monster truck tires... rounded the hex at the rear...think it's because of the solid rear axle...no diferencial...
So found a way to use those tires again...
Drill some holes into the rim, for the 6 screws... and use that green alloy spare i have from the last owner...
Fixed the issue for now! And able to run those tires/rims again!
-Already did a grass session on 3s!! Passed! Survived!
Also got a more wide stance at the rear now!
Old 04-29-2019, 07:48 AM
After that "extended" rear...
-Runtime! :P
Old 04-29-2019, 09:30 AM
Old 05-15-2019, 01:39 PM
Did a few small upgrades to the eletrics
-Added a capacitor to the rx. It avoid's the brownouts of the system! And helps a little for less heat (stress) of the system!
-And a programer card for the ESC. It came to me with to much brakes!! It was on the max setting! Cheap and efective till now!
Old 06-07-2019, 03:30 AM
How do you like the brushless? I prefer brushed in the AX10. I am running two 580's with 4WS. I also see you put a cap on the esc. I never do. I guess I like to live dangerously. Never had a problem though. The stock esc takes a program card? Looks nice though. I like your hexes/bead locks. Could get metal wheels for weight down low. If those are not already. You replaced diff? I thought it came with a plastic one.
crawlersrock is offline
