Soze's GMade Sawback 4LS
This is pretty much my first scaler/crawler type R/C. Pretty average normal build and nothing crazy like some of you more talented folks out there.
Follow this build on YouTube - https://www.youtube.com/playlist?lis...BSpTH1aFcEuuaO
Most product links are to the item on eBay. As an eBay Partner, I may be compensated if you make a purchase from the links below.
G-made Sawback 4LS Kit
Hobbywing 1060 Brushed ESC
PowerHD 20KG waterproof servo
GoolRC 27T Brushed motor
G-Made Aluminum CHub
G-Made Zero Ackerman Knuckle
G-Made Zero Ackerman Steering Links
G-Made Rock Sliders
G-Made Brass weights
G-Made CVA
Boom Racing Aluminum Servo Plate
I always forget to take pictures while I'm building.
Chassis pretty much built
A look at the Zero Ackerman Setup
A look at the electronics & motor have not started to clean up wiring yet.
Started paint on the body
Masked with masking tape only to find out later that the light kit included light masks!!! Grrrrr :x
Test fit.
Started applying decals.
Started wiring up lights
As it sits right now.
My first flex shot. Am I doing this right?
More to come. Sliders and brass weights are arriving today.
I have some ideas of what figures I want to use for the driver. Trying to decide if I should cut out a footwell so the figure will fit.
Also plan on getting scale accessories for the vehicle as well.
G-Made Rock Sliders
G-Made CVA
Test fit.
So I got around to installing a few of the other things. And ran into some hiccups.
Installed the G-Made Rock Sliders
Installed the G-Made Brass Weights in the front and rear.
Was on my way to installing the G-Made Long CVA kit for the 4LS but.... ran into issues. Apparently the CVA's I got were equal in length for both CVA shafts. Works just fine on the left side of the axle (driver's side), but too far out on the right side of the axle (passenger's side). It stuck out too far for me to put the knuckle back in place as the screw holes wouldn't line up anymore.
Not sure if this is because I am using the aluminum CHubs and zero ackerman knuckles.
I even took Jeepiac's recommendation of using Versachem!
Pictures of G-Made Long CVA Kit for 4LS
Anyway, put the dog bones back in and I'll wait for the GPM versions of the CVA's to get in. They should be in by the end of the week. Hopefully those work out just fine.
the 12mm / 6mm Wheel hubs I bought are also going to be held and used for my Sawback Sport kit. Apparently the 4LS uses 12mm / 10mm wheel hubs. So I guess I'll need to order the 10mm width ones now.
Got the G-Made CVA's to fit!!!
Thanks to some information to try it again from malickie.... They fit this time around. When I first tried it again, they still didn't fit in all the way. So what I did was force rotate the drivetrain/axle a little and that did the trick!
This side always fit in just fine.... you actually have to pull it out a little even though it can go in even further.
This was the problem side... I wasn't able to push it in enough to have the knuckle screw holes line up to secure the knuckle in place. Know it's all the way in and secured.
Alright, got my GPM CVD's in today.... and now I have to figure out what I want to do.
These GPM CVD's are for the Komodo which is same as the Sawback 4LS. Notice how the 2 CVD shafts are different in length? I think this is how it's supposed to be. The question is do I take the G-Made ones back out and use these instead? Or do I just leave as is and be happy that I finally got the G-Made ones to fit.
I would feel better with the GPM ones in there though, since the G-Made ones give little leeway on the passenger's side, and I'm afraid of possible binding at full steering angles.
How it sits right now with the rock sliders on. Have not gotten around to taking comparison pictures of the different CVDs and dog bones yet.
Next steps are to start adding some scale accessories and a driver. Still contemplating if I should cut that footwell for a driver.
I also want to get a rear bumper. Any good idea for a rear bumper anyone?
These parts came in this past week.
G-made 20031 Shock Spring 19X58mm Soft Green GMA0020031
1/10 Tow Shackle for Off-Road Trail Rock Crawling
Very cool build. I'm also building the sawback sports. Did you glue the light buckets I didn't get that far yet. I wanted a Sawback and did a some research on it (the regular kit and the sports kit) got the sports kit but missed the 4LS kit, luckily I found a 4LS kit and picked it up and I'm waiting to get it. I got a brushless tenshock crawler motor for it.
I've also got a Sawback Sport sitting and waiting to be built. Wanted one in each flavor.... leaf spring and 4-link.
I'm sticking to brushed setups for these rigs though. On the sport, I might pick up a Hobbywing 1080 esc. I've got one saved up for my SCX10 II, but might as well get one for the Sawback Sport as well.
