Go Back  R/C Tech Forums > General Forums > Crawler Room
Axial raw builders kit build >
Old 01-01-2019, 09:45 AM
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Default Axial raw builders kit build
Time for a new build, this one I'm going to try to keep clean and simple, with a few upgrades but not a ton of bling. I have parts and upgrades from other builds that I'm going to use. Any disappointment so far is the plastic body shocks, like many others I will not be using them.
roadrashracing is offline
Old 01-01-2019, 10:01 AM
Moderator
It all gets started with bag 1 and bag a.
The axles go together fairly easy, I gave the diff gears a good coat of marine grease. Here is what you end up with after bag a. There are a few less steps with one peice housings vs the other kit.
