Go Back  R/C Tech Forums > General Forums > Crawler Room
Knight Customs Inner Front Fender Install >
Like Tree1Likes
  • 1 Post By swang
Old 11-27-2018, 11:08 PM
Default Knight Customs Inner Front Fender Install
Hi, I have an Axial SCX10 II, Jeep Wrangler. I bought the Knight Customs front and rear inner fenders. I can't for the life of me determine how to mount the front fenders. Between the shock and the frame? Or behind the shock, mounted directly to the frame?
Please help!
Thanks in advance.
swang is offline
Old 11-28-2018, 09:44 AM
Not sure if the Knight Customs one are similar to the GRC ones that I bought, but here's my video on installing the GRC fenders.
soze is offline
Old 11-28-2018, 10:27 AM
Thanks soze! After watching the video, I donít think the Knight Customs mount the same.
swang is offline
Old 11-28-2018, 10:38 AM
Take a close look at these pictures. I think this shows how it's supposed to be done.
soze is offline
Old 11-28-2018, 04:22 PM
Hi soze,
I saw those pics last night. The front fenders look the same. The fenders didn't ship with any screws though, so I wasn't sure. The single screw in the pic is not stock. I think the parts bag that came with the Axial RTR may contain some screws, I'll have to check. Do you know what size screws those might be?
swang is offline
Old 11-28-2018, 05:35 PM
The one on the skid area is m3 size maybe 6mm (m3x6mm)? It's short though, because the side rails screw in from the bottom using the same hole. The top shock post ones are also m3 size. Maybe m3x8mm, m3x10mm or m3x12mm will work.
soze is offline
Old 11-28-2018, 05:57 PM
The holes on the back of the shock post arenít threaded. Do you think I should get something like a wood screw with more bite?
swang is offline
Old 11-28-2018, 10:03 PM
You shouldn't have to. The plastic should be soft enough for it to self thread. The original shock side was the same way if I recall.
soze is offline
Old 12-01-2018, 07:41 PM
I used a M3x6mm and it looks good, thanks for your help!
soze likes this.
swang is offline
