Go Back  R/C Tech Forums > General Forums > Crawler Room
Soze's GMADE GS02 BOM Build >
Like Tree2Likes
Old 09-20-2018, 11:43 AM
Default Soze's GMADE GS02 BOM Build
So I'm joining the party of BOM build threads. Since the other threads show more of the custom mods, etc. I'll post more detailed step by steps for the stock build for those of you that want to see that, until I fully finish and then venture off into upgrading parts and modifying.
Here's what we're building.
Follow this build on YouTube - https://www.youtube.com/playlist?lis...EJELNBdAKseKe1
Kit:
GMADE GS02 BOM (available on eBay)
Parts:
Yeah Racing Aluminum 540 Motor Spacer Heatsink (available on eBay)
Boom Racing 25T Alloy Servo Horn
Team Associated #5422 30wt Oil (available on eBay)
X-Rings from Traxxas 2362 Rebuild Kit
GS02 Hardened universal shaft set (J30035) (ebay)
GA44 Heavy duty diff locker (GM30112) (ebay)
BOM exterior detail parts tree (Black) [GM60120] (ebay)
BOM mirror L/R [GM30128] (ebay)
BOM cage hinge (Titanium gray) [GM30137] (ebay)
Crawler Innovations 1.9 XL Deuces Wild Single Stage foams (available on eBay)
Pro-Line 1.9 Super Swamper TSL XL G8 Tires (available on eBay)
Injora 1.9 Beadlock Wheels (available on eBay)
Axial SCX10 Wheel Wells (AX31150) (ebay)
GS02 aluminum shock brace GM30130 (ebay) (currently unused)
GS02 stainless steel front under guard GM30150 (ebay)
GS02 cantilever sway bar GM30143 (ebay)
GMADE Aluminum 12mm Wheel Hub (4) (8mm Thick) GM30131 (ebay)
Gmade - Rear Link Kit, 324mm Wheelbase GM30133, for GS02 BOM (ebay) (currently unused)
Gmade - Rear Link Kit, 336mm Wheelbase GM30134, for GS02 BOM (ebay) (currently unused)
Gmade Cantilever Arm Set, for GS02 BOM (Titanium Gray) GMA30139 (ebay)
GMADE Komodo Roof Rack & Accessories (ebay) (currently unused)
SSD Pro SCX10 II Aluminum Knuckles SSD00144 (available on eBay)
SSD Brass Weights (Black version) SSD00140 (available on eBay)
Electronics:
Turnigy MG959 V2 Servo (available on eBay)
Yeah Racing Hackmoto 550 35T Brushed Motor (available on eBay)
FlySky R6B 2.4GHz 6-Channel Receiver (available on eBay)
FlySky GT-3C 2.4 GHz Radio (available on eBay)
Tools:
Versachem Brake Caliper Grease
Noleen SF3 Grease (available on eBay)
Turnigy Metric Torque Wrench Hex Driver Set
Tamiya Side Cutter
DEWALT DCF610S2R 12V MAX Cordless Lithium-Ion 1/4 in. Hex Chuck Screwdriver Kit
MIP Metric Speed Tip Set MIP9512
Bob Smith Industries Blue Thread Locker
ProTek RC Shock Pliers (available on eBay)
Molotow Liquid Chrome Marker Set - 1mm, 2mm and 4mm
Tamiya PS-63 Bright Gunmetal (ebay)
Duratrax Gunmetal (ebay)
soze is offline
Steps 1-13: Axles
Let's begin
Parts needed for this step
Metal balls given to the first batch of BOMs
The well labeled hardware bags. Wish they would've went a step further and grouped the hardware by steps as well.
Ready to begin
Diff gears finished
Pinion Gear side of the axle
The other side of the axle
All greased up
C-Hubs going on
Front CVDs
Knuckles
Link mounts
Time for the rear axle
Front and rear axles all done
soze is offline
Old 09-20-2018, 11:44 AM
Steps 14-19 + 25: Transmission
We start with the B-bag.
Step 14 parts
Assembled gears
Parts for the next steps
Assembled and greased up
Spur gear goes on. They use stacked conical washers instead of a spring for the slipper. Directions say to fully tighten the lock nut, and then loosen by about a quarter turn. Here's how it looks.
Parts for the next step.. More e-clips yay...
Assembled gears...
Skipping to step 25 like new2rocks did.
Greased up. I wonder how the 2-speed option setup would look in this spot. That empty space has to be for something.
Transmission complete.
soze is offline
Old 09-21-2018, 12:03 AM
Steps 20-23: Links
This is going to be a pretty short step/post.
Bag of parts for these steps
Starting the front lower links
Front upper link
Rear lower links
Rear upper links
soze is offline
Old 09-24-2018, 12:00 AM
Steps 24 + 26-29: Chassis
Time to move onto the chassis. For this step, I also used the following non-kit items...
These are the parts needed for the battery tray
I'll be using the Turnigy MG959 V2 Servo and a Boom Racing 25T Servo Horn
Servo mounted onto the battery tray/servo mount assembly
These are the parts needed to start putting the frame rails together
It's starting to look like a chassis!
That under-frame receiver box that everybody has been putting weights in... I might do the same.
Time to get those links on
Links mounted
Parts for mounting the motor
I'll be using a Yeah Racing Hackmoto 550 35T Brushed Motor
So... I ran into a snag with this motor. The motor shaft is longer than normal, and I couldn't put the transmission cover on without hitting the motor shaft. So I had to get Yeah Racing Aluminum 540 Motor Spacer Heatsink
With the spacer installed, I was now able to have the motor shaft clear.
One thing I am concerned about is the pinion/spur mesh. It's tighter than I would like, and since the motor mount uses pre-set mounting holes, there's really no fine adjustment available. I will revisit this area later after I complete my build to see if there is a way I can make the pinion/spur mesh more to my liking.
soze is offline
Old 10-09-2018, 03:25 PM
Steps 30-35: Shocks
This update is going to be relatively straightforward.
I also used the Traxxas X-Rings from the 2362 Rebuilt kit like OSRC did.
Parts:
Bag "E" of shock parts.
Those blue X-rings inside the Traxxas 2362 Rebuild kit.
Duratrax Shock stand
Parts needed for Step 30
O-rings put around the shock caps
Parts needed for Step 31
Using the blue X-rings from Traxxas 2362 Rebuild Kit
Pistons on the shafts.
Time to put the front shocks together
Parts for Step 32
rear shock assembly getting there
Decided to put the rod-ends on early
Filling the shocks up with Team Associated #5422 30wt Oil (available on eBay)
Step 33 done
Parts for Step 34
Step 34 done
Parts for Step 35
Step 35 done
Shocks all done
soze is offline
Old 10-16-2018, 11:47 PM
Steps 36-48: Driveshafts, Suspension, Steering.
Covered a bit of ground in this update.
Getting on to the driveshafts. We'll need the F-Bag
Parts needed for lower front shaft
Lower front shaft attached to front axle
Parts needed for lower rear shaft
Lower rear shaft done
The upper half of the driveshafts
Parts for the cantilever suspension setup
Putting the cantilever setup together
Stock cantilever setup
Hooking up the upper shafts to the transmission
Front one going on...
Front shocks mounted
Time to get to the panhard rod.
Now for the steering rods
Was experiencing a bit of bump-steer with the combo of servo horn (Boom Racing low profile) and servo (Turnigy MG959 v2 30kg) that I was using, so I decided to add a 1mm spacer to correct that.
soze is offline
Old 10-17-2018, 07:16 PM
Steps 49-55: Electronics boxes, Sliders, Bumper, Body Posts
The BOM is really starting to come together now.
Non kit parts used in these steps:
1. FlySky FS-R6B Receiver
2. Hobbywing 1080 Esc (available on eBay)
My FlySky FS-R6B Receiver and where it's going...
Some parts for the wiring entrance of the receiver box.
This is where it goes on the truck
Going to be using a Hobbywing 1080 Esc (available on eBay)
Parts for the sliders
Mounted the box without the electronics for the time being.
Front bumper.
Body posts
soze is offline
Old 10-23-2018, 10:58 AM
Steps 56-58: Wheels and Tires
This is going to be a short step... not much to see here, and I'm just putting these together for the sake of the stock build documentation.
You're going to need these...
All mounted (little secret.. I haven't glued them yet)
Now you'll need these.
Ok.. this part done. See told you it was a short step.
soze is offline
Old 10-28-2018, 10:43 AM
Step 59: Rear Cage
Here's one of the cooler parts of this truck. I really like this rear cage/hinge setup.
Here are the parts needed
Rear Cage put together
Fuel cell painted up and attached to the cage
soze is offline
Old 10-28-2018, 11:20 AM
Steps 60-65: Body & Completion
It's taken be quite a bit of time, and I'm finally done with the "stock" build. I won't be stopping here though. I wanted to build this truck completely stock first just to get that out of the way, but now it's time to start modding and running.
Lexan cab ready for painting
Cab painted and decals applied. My Plasti-dipped fender flares need some work that I'll revisit later.
Here's the grille that I won't be permanently attaching, as I won't be using it.
These are the parts you will need for the front grille
This is how the front grille would look attached
Parts needed for Side mirrors and door handles
Mirrors and door handles attached
Rear cage attached
I love the rear cage hinge for this truck. Very convenient.
Stock build complete
soze is offline
Old 11-04-2018, 11:05 PM
Moving on to option parts and upgrades.
First up.... Junfac Drive Shafts and Upgraded Diff Lockers.
Here are the goods
Taking care of the drive shaft first.
Drive shafts added.
Stock diff locker about to come out
What's about to go into the axles
The indentation to properly assemble the diff locker
Upgraded diff locker assembled
Upgraded diff locker in the axle
Repeated the same process for the other axle.
soze is offline
Old 11-04-2018, 11:39 PM
Some cosmetic updates for the BOM.
The parts I'll be adding
Never really liked chrome. Just not a fan of it.
Door handles and side mirrors added
Used Molotow liquid chrome markers to properly chrome out the light buckets
[/url]
Prepping for mounting
Here's how they look mounted
Time to put on the hinge parts
So the hinge parts for the most part is just a preference, and not really an upgrade. The stock plastic ones for all intents and purposes work just fine.
The difference is that the option hinge lets you bolt down the hinge so that it stays on the chassis when lifted.
On the other hand.. the stock plastic one allows you to easily completely remove the body from the chassis by just sliding it out of the notch, whereas the metal option hinge would require you to unscrew it from the chassis.
It's really a preference, and I opted for the mounted to chassis option.
soze is offline
Old 11-08-2018, 10:37 AM
Upgraded the wheels and tires for the BOM.
Testing some image hosting out, so let me know if the pictures don't work.
This is the BOM on stock tire/wheel setup.
The Injora wheels
Crawler Innovations 1.9 XL Deuces Wild foams
Pro-Line Super Swamper TSL XL 1.9 G8 Tires
These are a perfect match
All foams inserted, ready for wheels
All the wheels & tires mounted together
How it sits now.
soze is offline
Old 12-22-2018, 03:42 PM
Some belated updates.
soze is offline
