Go Back  R/C Tech Forums > General Forums > Crawler Room
Build Complete: Traxxas TRX-4 >
Like Tree17Likes
Old 06-26-2019, 10:27 PM
  #16
Dave_S's Avatar
Originally Posted by fyrstormer View Post
Who makes that battery tray? Does it fit a full-size LiPo or only a shorty?
bowhouse rc.
it will fit full size lipo if you install the bracket it comes with.
Dave_S is offline
Old 06-27-2019, 09:27 PM
  #17
fyrstormer's Avatar
Interesting. How much of an improvement have you noticed?
fyrstormer is offline
Old 06-27-2019, 11:03 PM
  #18
Dave_S's Avatar
I haven't ran it both ways. Once truck is running again I'll try both battery trays and report back
Dave_S is offline
Old 06-28-2019, 08:24 PM
  #19
redmonster27's Avatar
Trader Rating: 31 (100%+)
Has anyone found any 10mm-12mm hex's that will fit on this truck I've got 2 different sets and neither will slide over the axle to the pin.
redmonster27 is offline
Old 06-30-2019, 05:19 PM
  #20
fyrstormer's Avatar
Sorry, I'm using the stock hexes.
Old 07-01-2019, 10:09 PM
  #21
Dave_S's Avatar
The difference seems negligible. I installed both, and measured at one point truck would pass center of gravity and tip over, measurement was nearly identical.
That was with stock battery, lift kit, brass front end.
on my truck i currently have yeah racing brass hexes. I'm probably going back to stock, because with the brass ones my sweet stock center caps won't screw on. (The ones that came in kit I bought are wider than stock)
Dave_S is offline
Old 07-01-2019, 10:43 PM
  #22
R/C Tech Elite Member
Trader Rating: 71 (100%+)
you may have to carefully drill out the center to get them to fit. Or see if you can find the hex's from a old school axial ax10 i know the axles on the ax10 had a slight "step up " at the knuckle end
Dave_S likes this.
freaksofnature is offline
Old 07-03-2019, 01:09 AM
  #23
Dave_S's Avatar
here is pic with full size lipo installed if you are interested. Or even if you aren't, I suppose.
fyrstormer likes this.
Dave_S is offline
Old 07-12-2019, 02:52 AM
  #24
Cesco's Avatar
Nice looking TRX-4 with all the right upgrades. Like it.
Cesco is offline
