Go Back  R/C Tech Forums > General Forums > Crawler Room
axial Bomber motor ?? >
Old 08-20-2018, 02:26 PM
Default axial Bomber motor ??
Hi , need some help with deciding which motor to put in a bomber kit that I have purchased Iím wanting to set it up for Ultra 4 .i also purchased the 2 speed transmission for it . I am new to all this so would appreciate some ideas, was looking at the castle creations 14 series motor but not sure what size would be best suited. Thanks
Torque 6 is offline
Old 08-26-2018, 01:05 PM
Backyard RC's Avatar
I'm not sure why nobody wants to touch this one.
The Castle Creations sensored set up would work really well. The KV choice would depend on what cell batteries you want to use. 2s will be better in the higher KV motors. If you want to run in the water and mud then maybe a brushed motor set up is better due to the lower costs if you burn it out.
Holmes Hobbies has some really good stuff and worth a look.
Backyard RC is offline
Old 08-27-2018, 03:04 PM
the rc guy's Avatar
isn't this a 1/10 scale rc?.. why show a 1/18 or 1/14 scale motor.2 speed trans whats its kv max rating?..id go brushed unless you need a new esc ..id just get a sealed can 1200kv and hav fun..
the rc guy is offline
Old 08-28-2018, 11:29 AM
I got the RR10 kit with two speed. I set the two speed up at the far ends (max lo and max hi). Castle Mamba X and 1409-1900kV, on 3S. I could not be happier with it. I usually run in Hi, and if something really needs some grunt, downshift.
Castle product: MAMBA X, SENSORED, 25.2V WP ESC AND 1406-1900KV SENSORED COMBO
Racer Rob is offline
Old 08-28-2018, 02:20 PM
Thanks for the info much appreciated, will shop around the 1900kv set up sounds good , if a went for 3800kv motor does it give me speed or torque on 2s or 3s . Also has anyone know much about the Tekin 412 motor line
Torque 6 is offline
Old 08-28-2018, 04:10 PM
the rc guy's Avatar
3800 kv on 3 cells is way to many kv..max id go is 3500k..
Old 08-28-2018, 05:21 PM
Ok , so what is the difference going to be between the 1900kv motor and the 2200kv motor of castle creations?
Torque 6 is offline
Old 08-28-2018, 05:48 PM
And let me confuse it some more. I misremembered, I got the 2850kV combo. But I correctly remember it's been great fun. My friend on youtube, JoeOvercoat, has some videos.
Only issue I had was breaking ujoints. So I repleced the drive line with supershafty's kit (they kit up MIP components). I haven't broken one since.
Old 08-28-2018, 05:52 PM
For a given battery, higher kV makes higher rpms.
I chose a middle/high kV because sometimes you need wheel spin and low rpms just won't deliver. Then the lo gear is at the bottom limit, so it gets max torque despite the higher rpm. Also, since it's sensorsed, it's really good about slow speed control.
Old 08-29-2018, 03:38 PM
Thanks Racer Rob , have looked at the 2850kv castle creations motor think itís the combo with the mamba x . Had a look at joe overcoat on YouTube could not find a axial bomber or is the motor in another vechicle.
Torque 6 is offline
Old 08-29-2018, 04:56 PM
outube.be/nDrFdyc5XBk
outu.be/VEZH91kGh9I
you'll need to put the http stuff and a y in front. I still can't post urls.
