Go Back  R/C Tech Forums > General Forums > Crawler Room
Soze tinkers with son's Ascender K10 RTR >
Like Tree1Likes
  • 1 Post By soze
Old 06-20-2018, 12:26 AM
Default Soze tinkers with son's Ascender K10 RTR
So last year I picked up a Vaterra Ascender K10 RTR for my son. I haven't done much to it, but after having recently picked up an Ascender Kit of my own due to the lower price... I have renewed interest in tinkering with it.
Follow this build on YouTube - https://www.youtube.com/playlist?lis...KA4o7o7AlI6sOT
Build Details:
Parts:
RC4WD Tough Armor Steel Sliders for Ascender
Vaterra 340000 Light Set with Buckets
MIP X-Duty C-Drive Kit for Vaterra Ascender
Electronics:
Sanwa MX-V Transmitter w/Sanwa RX-371W Receiver
PowerHD 23kg Servo
HeyOK Performance RC Switch for LEDs (available on eBay)
Here's how the truck looked when I first got it. So clean and fresh
soze is offline
Upgrading the servo, adding RC4WD Tough Armor Steel Sliders.
I did these upgrades mid 2017.
First thing I did was replace the stock Spektrum servo with a PowerHD 23KG Servo
Next up was adding the Rock Sliders. You'll need the following to add these rock sliders to the K10 RTR
- RC4WD Tough Armor Steel Sliders
- Vaterra Ascender VTR231038 Battery Tray Mount & Parts
Pre-Slider look
Battery tray mount in order to add the sliders
Sliders mounted
soze is offline
Old 06-20-2018, 01:53 AM
I've been wanting to add headlights to this truck for a while and finally got around to ordering the parts.
I used the Vaterra Light Set with Buckets for the Headlights.
Removed the grill from the body.
Took a dremel and dremeled out the headlight area in the grill
Made the necessary cutout in the body for the headlights
Took an exacto knife and scored lines into the lenses from the light bucket kit.
Adding the LEDs
This is what they look like when the assembly is put together
I used the almighty Shoe Goo for gluing the grill and light buckets to the body.
Shoe goo'ed the grill onto the body, and then Shoe goo'ed the light buckets to the inside of the body.
Here's what they look like fully attached.
I also used the HeyOK Performance RC Switch for LEDs
LED Switch tucked away in the receiver box
Routed the LED wire along the same path as the servo wire
Let there be light!
kwkride likes this.
soze is offline
Old 06-20-2018, 11:14 AM
Backyard RC's Avatar
Looks good!
Thanks for showing how you did the lights.
Backyard RC is offline
Old 06-21-2018, 10:01 AM
I forgot to mention I added the MIP X-Duty C-Drive kit Driveshafts. I did this before the headlight addition.
soze is offline
