Go Back  R/C Tech Forums > General Forums > Crawler Room
Mini Crawler track for Orlandoo Hunter Pajero OH35A02 >
Old 02-25-2018, 09:18 PM
Gramps50's Avatar
Default Mini Crawler track for Orlandoo Hunter Pajero OH32A02
After buying and building a Orlandoo Hunter Pajero OH35A02 I need a place to run it. Decided to build a mini crawler track that would be portable and I wanted to be modular so I could add on to it in the future. I decided to build it on a 36"x36" base. After a few mock ups I decided on what I wanted. Began cutting some 1" polystyrene board. Started with a 3'x3' base and started building from there. When I go the basic design roughed in I tested the Pajero on it.
https://youtu.be/hrhT1JCmtMU
As it turned out when I started building the final version I didn't have enough room to get back down from the 2nd level without backing up and coming down the same way I went up. The 2nd level stayed but there's no way to get to it. Still have to construct a bridge from the 1st level on the right back down to the left. Add some crawling obstacles under the ramp and platform and between the two.
Gramps50 is offline
Old 02-28-2018, 05:48 PM
xl-racing's Avatar
Wow, nice touch on the terrains works. Looks like white sands.
xl-racing is offline
Old 03-03-2018, 08:15 PM
Gramps50's Avatar
Wanted a rubble field under the platform, glued all the rocks in place, then put down a coat of watered down PVA. Spread some fine rubble over the glue and let it dry. Did about half of it. Let it dry the dumped off the excess.
Gramps50 is offline
Old 03-04-2018, 01:18 AM
xl-racing's Avatar
Wow, lot of detailed stuff to work on the track. Thumbs up.
Old 03-04-2018, 09:36 PM
Gramps50's Avatar
Started putting the rock wall on the ramp/platform. Tried to hot glue then to the foam, didn't work well. It would stick to the foam but not to the plaster paris for what ever reason. Might have been able to do it with PVA but it has no sticking power until it's dry. Using a tip from a FB group I ended up using Locktite PL300 which for gluing foamboard to a wall or even drywall to foamboard. Still tkes 24 hrs for it to dry but it does have some holding power to it makes it easier to set the panels.
Gramps50 is offline
Old 03-11-2018, 06:58 PM
Gramps50's Avatar
Finally got all the panels glued in place.
Filled the joints with speckling compound
Added some rocks to the ramp
Wanted a little texture on the top
Gramps50 is offline
Old 03-13-2018, 08:44 PM
Gramps50's Avatar
Decided to paint it modular before I glued it all together, much easier. This was the easiest piece to replace if I didn't like it. This isn't finished yet it will still get a gray wash then dry brushed in white.
Gramps50 is offline
Old 03-14-2018, 01:13 AM
xl-racing's Avatar
Nice work on the paintjobs, the terrain texture started to get some scale realism. Great job can't wait to see the results.
Old 03-16-2018, 09:45 PM
Gramps50's Avatar
Did some more painting today
The next step is finishing the base so it to can be painted.
Gramps50 is offline
Old 03-17-2018, 08:34 PM
Gramps50's Avatar
Think I have decided to leave the 3rd story off. It served no real purpose and would limit some what the view of the 2nd level. So I think this is what the 2nd level will look like.
Gramps50 is offline
Old 03-18-2018, 06:11 AM
xl-racing's Avatar
Looks superbly well done on the paint jobs, terrain texture looks alive.
Old 03-18-2018, 07:01 PM
Gramps50's Avatar
Thanks XL, I started working on the base again today. Carved up the base some more and added a 2nd ramp in the back for another way to get on and off the deck.
With the painted piece in place
Gramps50 is offline
Old 03-22-2018, 08:56 PM
Gramps50's Avatar
Before starting the final painting I decided to give the course a test drive using my Orlandoo OH35A1 Jeep. Did find a few things that will need fixing.
https://www.youtube.com/watch?v=V-B4__jWyls&t=11s
Gramps50 is offline
Old 03-26-2018, 09:05 PM
Gramps50's Avatar
Started adding rocks to the other side to make it more challenging.
Gramps50 is offline
Old 03-29-2018, 03:33 AM
xl-racing's Avatar
Any plans to add vegetation objects?
