Go Back  R/C Tech Forums > General Forums > Crawler Room
How to stop wheel lift when turning? >
Old 02-10-2018, 07:27 PM
Default How to stop wheel lift when turning?
I have an old Kyosho Rock Force I just built. First run, everything went smoothly except when doing full turns the inside front wheel lifts up. When making a right turn it lifts up about 1.5 inches and when going left its just barely touching the ground.
Mostly stock, used metal chassis braces and aluminum wheels and flat iron tires. Tried to follow the manual down to the MM. Has 4 wheel steering.
MaxxGabriel is offline
Old 02-12-2018, 07:27 AM
R/C Tech Elite Member
Darkgenerals's Avatar
Trader Rating: 66 (100%+)
torque twist? Try a anti roll bar, this is how axial does it on most of their solid axle stuff.
Darkgenerals is offline
