HSP RTG ADVENTURER 1/24 like ECX mini barrage
Thanks for the vid review! Neat little truck.
I was searching for it on ATees based on the name of your post but couldn't find it. Finally, I learned it's 'RGT', not "RTG".
Great unboxing! I have the same one coming in yellow. It's not clear on Asia Tees that it has LEDs, so I was very pleased to see that in your video. Nice to have a thread to post my experiences with my first micro crawler here. I was surprised by how zippy it seems. I hope it is good at climbing home-made obstacles courses made from pillows and toys and stuff.
Thanks for the running vid!
I really like the looks of the Adventurer. It would appear from your video that the truck is geared way to tall/high for actual crawling. Wonder if there will be any parts out there to lower the gear ratio???
Your welcome, Yes it needs more power a hop up motor or maybe if they make gears for it to give it more low end power. I seen a guy use 2s on the FTX version that may give it a lot more power but also a lot more speed?
I don't trust using 2S just yet I will wait a while to see what guy's say about running 2S as I don't want to blow things out on it.
I am hoping they will make hop ups I think they will since there are 3 versions of this out now the RGT, ECX, and the FTX .
HSP needs to send you some free vehicles being your videos are going to sell every RGT Adventurer they can get off the assembly line!
That's a pretty impressive little truck! If a 1-tooth smaller pinion could be found to fit that motor the truck would 'crawl' better. It would be easy to take a Dremel and oblong the holes for the motor screws so proper mesh could be achieved with a smaller pinion.
Thanks again for the great videos!
Thanks I know another guy who said he has pinions that fit and he ran a 10T but wants to put a 8T, I know you have to mod the motor mount so the motor can be adjusted but it should be very simple.... Just don't know what pinions he is using so I asked him. I would love to put a 8T and mod it to work.
If it's a 2mm shaft there are quite a few choices.
