Go Back  R/C Tech Forums > General Forums > Crawler Room
Soze's GMADE GOM GR01 Build >
Like Tree3Likes
Old 10-27-2017, 12:25 PM
Default Soze's GMADE GOM GR01 Build
So... finally getting around to my GMADE GOM GR01 build. Just started today, and I'll post up progress as I go along.
Follow this build on YouTube - https://www.youtube.com/playlist?lis...uh2tDJhRxhYztU
Build Details:
GMADE GOM GR01 Rock Buggy Kit
GMADE GOM Sway bar set (Titanium gray) GM30115 (available on eBay)
GMADE GR01 Aluminum rear shock brace (Titanium gray) GM30080 (available on eBay)
GMADE GR01 Aluminum slipper plate GM30073 (available on eBay)
GMADE GA60 Brass steering knuckle bushing (4) GM30076 (available on eBay)
GMADE GR01 Machined M4 99mm Upper Link (Titanium gray) GM30105 (available on eBay)
GMADE GR01 Aluminum trailing arm (Titanium gray) GM30107 (available on eBay)
GMADE GR01 Aluminum HI/LO Shift Fork GM30087 (available on eBay)
GMADE GA60 CVA kit GM30062 (available on eBay)
GMADE GR01 Aluminum Skid Plate (Titanium Gray) GM30111 (available on eBay)
JunFac GA60 Aluminum Panhard Bar Axle Mount (Titanium Gray) J30009 (available on eBay)
JunFac Hardened Universal Shaft for GMADE GOM Rock Buggy J90036 (available on eBay)
GMADE Aluminum Shock Upper Ball 8x8.5mm Red GM0020095 (available on eBay)
Vanquish 25T Aluminum Servo Horn (available on eBay)
Pro-Line 2.2 Single Stage Rock Crawling Foam (for use with stock GMADE MT-2202 Tires)
Pro-Line 2.2 Dual Stage Closed Cell Crawl Foam (for use with Pro-Line Hyrax 2.2 Tires)
Motor:
Brushed - Traxxas Titan 21T
Brushless - SkyRC Ares Pro 540 Modified 8.5T (4100Kv), or Holmes Hobbies PULLER PRO BL 540 STANDARD (3500kv)
Electronics:
Hobbywing WP-1080 Brushed ESC Or Castle Creations Mamba X
FlySky R6B 2.4GHz 6-Channel Receiver
FlySky GT-3C 2.4 GHz Radio
Savox SC-1283SG Servo - (for steering)
Savox SC-0254MG Servo - (for shifting)
Tools / Materials:
Versachem Brake Caliper Grease
45 in 1 Precision Screwdriver Set
Hakko FX-888D Soldering Station
Tamiya Side Cutter
DEWALT DCF610S2R 12V MAX Cordless Lithium-Ion 1/4 in. Hex Chuck Screwdriver Kit
MIP Metric Speed Tip Set MIP9512
Noleen SF3 Grease (on eBay)
Tamiya PS-30 Brilliant Blue
Tamiya PS-5 Black
Upgrades on the way
JunFac Hardened Steel 32P 16T 1st gear (LO) (J30020) (available on eBay)
JunFac Hardened Steel 32P 35T 1st gear (LO) (J30021) (available on eBay)
JunFac Hardened Steel 32P 21T 2nd gear (HI) (J30022) (available on eBay)
JunFac Hardened Steel 32P 30T 2nd gear (HI) (J30023) (available on eBay)
JunFac Hardened Steel 32P 22T Transfer Case Gear (J30024) (available on eBay)
JunFac Hardened Steel 32P 40T Transfer Case Gear (J30025) (available on eBay)
JunFac Hardened Steel 32P 40T Transfer Case Dig Gear (J30026) (available on eBay)
Gmade GOM JunFac GA60 Aluminum Straight Axle Adapter Gray Set RC Cars #J30011 (available on eBay)
JatoTheRipper likes this.
soze is offline
I forgot to take some photos during the beginning steps, but I'll remember going forward.
Steps 1-13: Front and Rear Axles
soze is offline
Old 10-27-2017, 06:21 PM
JatoTheRipper's Avatar
Ah a familiar name. Those axles are freaking awesome looking!
JatoTheRipper is offline
Old 10-31-2017, 11:37 PM
Used Versachem Brake Caliper Grease to grease the gears.
Steps 14-18: Transfer Case
soze is offline
Old 11-06-2017, 12:10 AM
Also added the GR01 Aluminum slipper plate (GM30073).
Temporarily using a SkyRC Ares Pro 540 Competition 8.5T (4100kv) brushless motor for now. If I use this, I'll be using the Castle Mamba Monster X Esc.
If I go the brushed route, I'll probably use the Hobbywing 1080 Esc + Maybe the Traxxas Titan 21T.
Steps 19-27: Transmission
soze is offline
Old 11-06-2017, 07:06 AM
R/C Tech Elite Member
Darkgenerals's Avatar
Trader Rating: 66 (100%+)
Nice looking so far. Those gears second photo look so weak. I've never been a fan of powered metal.
Darkgenerals is offline
Old 11-06-2017, 09:54 AM
So far some people have put some decent power through this truck without any issue, so hopefully that stays the case.
soze is offline
Old 11-06-2017, 01:22 PM
Thats good to hear, I really like the look of these trucks.
Old 11-09-2017, 08:33 PM
Steps 28-37: Links
Bought the upgraded trailing arms
Comparison of stock trailing arms with the upgraded ones
Links attached to skid
soze is offline
Old 11-09-2017, 08:34 PM
Steps 38-45: Lower Chassis Part 1
Transfer case, shift servo (Savox SC-0254mg), and transmission attached to skid. Using a SkyRC Ares Pro 8.5T (4100kv) brushless motor for now.
Shift servo calibration using the 3ch 3position switch on the FlySky GT3C
soze is offline
Old 11-09-2017, 08:35 PM
Steps 46-54: Lower Chassis Part 2 - Lower and upper front cage, battery tray, driver's side chassis rail.
soze is offline
Old 11-09-2017, 08:36 PM
Steps 55-60 - Drive Shafts, Attaching Axles to chassis.
soze is offline
Old 11-09-2017, 08:37 PM
Step 47: Steering Servo
I skipped this step earlier, because I'm using the Savox SC-1283SG Servo.
The kit comes with pre-molded servo spacers that encase the servo ears. They are pre-molded to fit most servos that use thinner plastic servo ears.
The Savox 1283 is metal cased, and has thicker servo ears so the pre-molded servo spacer didn't fit.
What I ended up doing was to use Yeah Racing M3 3mm spacers to space the servo up.
soze is offline
Old 11-09-2017, 08:38 PM
Steps 61-68: Shocks
I really need to get some more specific tools to do some of these build steps like the shocks. I'm sure I can do a much better job, but for now I'll keep winging it and improvising with the tools I have.
Applying some Noleen grease (found on eBay) (thanks Jato!)
Bought the upgraded metal rear shock brace for the GOM
soze is offline
Old 11-09-2017, 08:49 PM
Steps 69-74: Steering & Panhard Links/Rods
So, I did run into a snag here. The panhard axle mount that the panhard rod attaches to on the axle uses a countersunk screw to secure it into place. The "eye" of that mount for that countersunk screw isn't very sturdy.
Well... like someone from another forum that did the same thing that I didn't really remember until I did it myself.... I overtightened it by hand and "split" goes the eye of the panhard mount. Grrrr .
It will hold for now as the other half of the eye is not broken.
Anyway, I ordered the sprue that contains that particular part for now, while I wait for the upgrade metal part to show in stock at vendors. The panhard axle mount metal upgrade is one part that I WILL BE DOING.
soze is offline
