Axle Conversion
Old 06-21-2004, 09:09 AM
TeamPink91's Avatar
Default Axle Conversion
Is there a company that makes a rear axle that would fit in a sp12m so I could use regular wheels instead of corally style only.
TeamPink91 is offline
Old 06-21-2004, 11:40 AM
Not for many years now.
BullFrog is offline
Old 07-15-2004, 07:29 AM
EPeters's Avatar
Default Re: Axle Conversion
???YES??? goto your nearest kite shop.
Buy Carbon/graphite tubes and you are able to glue a different dif. disk on it.
I did the same withe my own c10x axle bought 8mm carbon (by a kite shop) and glued the disk on it and cut the treath on it with a normal treath cutter. (for glueing??? use 2 comp epoxy glue)
Now your able to create all the axle's you want.
Massive, hollow and ofcourse wider axle's up to 2 cm.
Pro10 all the way
EPeters is offline
