CRC 1/12th Scale
I was Given a CRC 1/12th scle and it seems to have a bent rear hub on it but i dont know what car it is. I know it is a CRC because it has CRC machined into the back of the rear Pod. the pod is polished and it has a center shock with two polished slinding links from the center mount, 1 to each side.
can any one tell me what car it is so i can try and get parts for it. i have run the car. its fast but a small bend in the diff side hub. Thanks:D |
1. This is the Corally forum, not the CRC Forum. Try the 1/12th forum under electric onroad.
2. Are you sure it's the hub that's bent and not the axle? 3. A hub from most of the other cars out there should work. Check your tracks stock and see if they have something the same length. |
Originally Posted by Az-Cowboy
(Post 5725921)
can any one tell me what car it is so i can try and get parts for it. i have run the car. its fast but a small bend in the diff side hub. Thanks:D It sounds like a CRC 3.1. Parts are very easy to get for this car from your LHS or CRC's website. |
Originally Posted by wingracer
(Post 5726613)
