SP12m Setups
Old 11-08-2006, 01:23 PM
Greg Amendola's Avatar
Trader Rating: 28 (97%+)
Default SP12m Setups
Just looking for setup advice for 12th stock on the sp12m Ahoniemi edition.
BTW, hey Jeff!
Greg Amendola is offline
Old 11-12-2006, 08:43 PM
Rick Pfeilstick's Avatar
first you start with a x not a m
Rick Pfeilstick is offline
Old 11-13-2006, 10:58 AM
Very helpful
kiwirevo is offline
Old 11-13-2006, 03:23 PM
I am still running my SP12M out of the box, it's working great. I only run modified outdoors and it is always handling pretty good.
Some points to consider below.
1. Tyre choice is obviously important, depending on the grip I only use Corally Gold Front & Rear. Or Silver Front & Rear. If you are racing stock on carpet I'm not sure, probably silvers as they are a bit harder.
2. Keep an eye on the ride height, you want about 4mm all round. Your kit should have the adjustable axle height and the shims under the steering blocks.
3. Make sure the diff is in good condition, definitely not notchy and not too loose either. As loose will ruin it quickly.
4. Make sure the rear end is not tweaked, there are some adjustments on the t-bar near the front. Make sure your motor wires don't bind anywhere.
5. The Medium or Hard Syrup in the damper pod works for me.
Hope this helps.
PS. I will wait until they produce a battery strap for the "X" version before I buy one.
Regards,
Matt Dall is offline
Old 11-13-2006, 08:37 PM
Here's a setup I found for you don't know if it helps but
http://www.corallyusa.com/2005/setup...birdsChris.pdf
kiwirevo is offline
Old 11-22-2006, 02:23 PM
Thanks, theres some good info there.
Old 12-07-2006, 05:38 AM
where do I get a wide rear axle, 3mm wider?
Old 12-07-2006, 04:07 PM
Rick, I've never seen one?? Why would you need one?
Unless it's an option part i've never seen you may have to make it yourself.
Regards,
