Best way to heat garage/ shop >
Old 11-19-2015, 10:21 PM
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Default Best way to heat garage/ shop
This is the first winter season in my new work place, my wife already gave me a big heck now to bringing my space into the house. I would like to be able to work out there when I please. The space is 16x22. Not sure what the best option is. I was thinking about just making myself a little temporary room and just heat that with a little oil filled radiator type heater.
roadrashracing is offline
Old 11-20-2015, 02:00 AM
Trader Rating: 114 (100%+)
http://www.homedepot.com/p/Fahrenhea...UH54/202043073
$255
Seether is offline
Old 11-20-2015, 07:00 AM
flou's Avatar
Trader Rating: 18 (100%+)
I used an oil filled radiator in our last garage. Worked great. My garage was around 700 sq/f and not insulated.I was able to keep the room mid 60 running the heater on medium. That's with an outside temp of mid teens .a small fan on low pulling the warm air helped tons.
flou is offline
Old 11-20-2015, 10:48 AM
Digit09's Avatar
How big is your budget?
Digit09 is offline
Old 11-20-2015, 12:03 PM
sakadachi's Avatar
Another option is to use IR heaters.
I also recommend running a humidifier if the air outside the garage is below 32F. It will get VERY dry in the garage.
Hygrometer is a great device to have. GL
sakadachi is offline
Old 11-20-2015, 12:44 PM
Here is one I use in my barn and it works perfectly. And it's only $99.
http://www.tractorsupply.com/tsc/pro...er-18-000-btus
Wolverine7 is offline
Old 11-20-2015, 01:04 PM
flou's Avatar
I'm sold lol. That's a dang good bargain. 18000btus for 100 bucks
flou is offline
Old 11-21-2015, 03:54 AM
lemonader83's Avatar
Trader Rating: 16 (100%+)
In theory, and I'm really just writing this bc I'm bored, the best way to heat a garage for the least amount of money would be to light the garage on fire. One book of matches costs less than $0.25.
lemonader83 is offline
Old 11-21-2015, 09:13 AM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
I've tried this style of propane heater and for ME they STINK, as in smell. So much so that I returned it after 5 minutes of use.
The style you posted might not be an issue, never tried one.
racer1812 is offline
Old 11-21-2015, 11:56 AM
Moderator
I'm going to give this a try:
http://www.mrheater.com/big-buddy-portable-heater.html
Old 11-21-2015, 06:34 PM
flou's Avatar
Ya those don't burn as clean. That style is for like an open construction. No windows in yet type stuff. Lol. The radiant style get so hot smell is burned off.
flou is offline
Old 11-22-2015, 04:32 PM
Check codes in your area if you go with anything besides a normal electronic heater. My grandpa bought and installed a nice propane heater and then it turned out to be a large fine in his area.
nerdyrcdriver is offline
Old 11-23-2015, 08:43 AM
Digit09's Avatar
Not sure how much you care to invest, but you can install a mini split heatpump. The R-410a systems produce good heat even down into the teens. From my experience the oil filled radiators tend to be the best all around solutions. They are cheap compared to most systems, last a long time, clean and scent free, easy to move and fairly cheap to run.
What about a wood stove??
Digit09 is offline
Old 11-24-2015, 08:08 AM
Super Moderator
racer1812's Avatar
BIG "no-no" with just about every home owner policy in our state.
Old 11-24-2015, 08:57 AM
Jaymancd's Avatar
who says they have to know? I have a large propane heater in my shop that no body but my dad and I know about. Just guessing but it is probably not to code, but man it gets an uninsulated oversized 2 car shop in the low teens to around 40 or 50 F and thats perfect for us. It uses a lot of gas, but usually worth it.
Jaymancd is offline
