Tire Pressure Monitor System >
Old 03-24-2013, 02:35 PM
Default Tire Pressure Monitor System
Any experts out there? I have a 07 GMC Z71 and recently "Re-Learned" tire positions which seemed to go well. Soon after, 'Service TPMS System" light came on. Any ideas?
poppa_duce is offline
Old 03-24-2013, 07:51 PM
GundamWZero's Avatar
Pot hole?
Normally that is the culprit once you hit them...
GundamWZero is offline
Old 03-24-2013, 08:31 PM
Super Moderator
Slo_E4's Avatar
Trader Rating: 61 (100%+)
Look in your manual, most likely it involves releasing pressure from each tire so they can be recognized to where they are now located.
Im no expert, I just recently got new tires on my wife's buick enclave and had the same dilemma.
Slo_E4 is offline
Old 03-24-2013, 08:39 PM
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Most likely a sensor went or is going bad. After about one year the batteries in the sensors go weak. Do you notice if the message shows up when it's cold outside? If so, a weak sensor could be the problem.
SpraydbySprague is offline
Old 03-24-2013, 09:13 PM
Originally Posted by GundamWZero View Post
Pot hole?
Possible since I drive in Houston everyday, But it came on immediately after relearning tire position.
Have tried that procedure twice and get the honk that is suppose to mean op was a success.
On constantly, flashes for a few minutes then goes solid.
Everything else still works- door locks/unlocks and remote start.
Old 03-24-2013, 09:35 PM
Super Moderator
Slo_E4's Avatar
Since it happened immediately, id imagine the procedure was not a success, even though you got the honks... Could be one of them is going bad. I'd try the procedure again, and if fails take it to a tire kingdom or something.
Slo_E4 is offline
Old 03-25-2013, 05:43 PM
Cinnabun's Avatar
Trader Rating: 27 (100%+)
If the horn honks while releasing tire pressure during the relearn for each tire, than all sensors are operating.
I'm assuming you are setting up the relearn correctly? Horn should honk twice, and relearn active should be on the dash. Let air out of LF wheel until horn honks once, move to RF let air out wait for honk, RR let air out wait for honk, LR let air out wait for honk twice and dash should say relearn complete/success/ something like that? Cycle the ignition to off, and start the truck and tire positions should be learned.
Have you checked the spare tire pressure? Vehicles can have a sensor in the spare as well.
Cinnabun is offline
Old 03-26-2013, 10:18 AM
I have not checked the spare. I have repeated the "Relearn" procedure three times per the manual and get confirmation at each tire. Not that big of a deal really, I just hate looking at the light.
Old 03-26-2013, 11:03 AM
Trader Rating: 37 (100%+)
You probably have a bad sensor. I had the same issue with my work truck.
chensleyrc1 is offline
Old 03-26-2013, 07:50 PM
Cinnabun's Avatar
A sensor can't be bad if he gets confirmation honk at each tire.
Cinnabun is offline
Old 03-26-2013, 08:34 PM
KC10Chief's Avatar
I've had this issue very recently where it wouldn't relearn the tire pressure sensors. My problem was in the Remote Control Door Lock Receiver (RCDLR). Your tire pressure readings pass through this sensor even though your key fobs work fine. I had to take it to the dealer so the GM guy can hook up his Tech2 machine to make the RCDLR relearn the tire pressure sensors. That was $80 of fun. If you figure it out without having to use a Tech2 machine, please let me know!
KC10Chief is offline
