In need of a computer GURU >
Old 09-26-2011, 05:15 AM
FATKAT's Avatar
Trader Rating: 25 (100%+)
Default In need of a computer GURU
I need some help.
I have to do monthly lighting reports for buildings and I need a way to scan in to my computer simple line drawings of the properties and have them be editable so I can add simple notes such as "OUT", "DIM", Going On and OFF etc...
I already have the scanner etc.. what I need to know is how to make the drawing editable so I can mark the lights with problems and email them to property managers so they can arrange repair
This make an since, I think it should be simple I just cant figure out the best way to do it.
Can the drawing scan be convertid to a WORD document?? Will that work?
FATKAT is offline
Old 09-26-2011, 06:24 AM
GundamWZero's Avatar
You need Adobe Acrobat.... the REAL one.
The Acrobat you can get nearly for free only allow you to read .pdf files, but you need to edit or write on to it as well.
GundamWZero is offline
Old 09-26-2011, 08:47 AM
Cpt.America's Avatar
Trader Rating: 52 (100%+)
he asked for a computer guru.
You don't need Acrobat, the real one OR the fake one. What you need is a PDF markup program. I have been using the following app for years, and it is great. You can write onto any pdf. You can do text, make circles or shapes, draw on it, whatever you want, and then re-save the PDF. All you need to do is make sure that your scanner initially scans the file to PDF format. You would then open that pdf in this program.
It's called PDF Xchange Viewer, and it's free. I can even email it to you if you want, just send me a PM.
Cpt.America is offline
Old 09-26-2011, 09:42 AM
FATKAT's Avatar
Thanks for the replies
FATKAT is offline
Old 09-26-2011, 10:22 AM
whitrzac's Avatar
Trader Rating: 96 (100%+)
Wouldn't scanning it as a pic(JPEG, png, etc) and using MS paint work just as well?
whitrzac is offline
Old 09-26-2011, 10:59 AM
StarrRacing's Avatar
Which is what I was going to say.....
Scan it as a .jpg....
Open it in Microsoft "Paint" (it is Free, comes with Windows, under Accessories)
Add a text box and type away.....
Save....
Done.
StarrRacing is offline
Old 09-26-2011, 12:11 PM
neobart's Avatar
Ahh the K.I.S.S. approach.
neobart is offline
Old 09-26-2011, 12:58 PM
oXYnary's Avatar
Plus you then have to assume that the computer on the other end has acrobat. What if they are looking at it through a smartphone on the site?
As said, KISS. Just scan to a jpg, markup, zip, and send to recipient.
If you dont think Ms Paint will do it. http://gimp-win.sourceforge.net/
oXYnary is offline
Old 09-26-2011, 02:54 PM
Smart phones can open pdfs just fine.
Old 09-27-2011, 03:27 AM
FATKAT's Avatar
Thanks for all the ideas.
My Adobe program has he sticky note feature but if you print the drawing it dosent print the note. I will give the MS Paint thing a try a and see if I can do what I want that way.
Thanks again
FATKAT is offline
Old 09-27-2011, 07:55 AM
FATKAT's Avatar
OK, lets go a little further. I have been playing with MS Paint and I can do what I need to do with it.
I still need to get this back to a PDF format and I have DORO Printer installed and can reprint the scan with doro to a PDF file.
The problem I have now is the size. When I try to print, it is a 16 page file in doro pdf. I need it to be the original size that fits on one standard sheet of paper.
Any ideas
FATKAT is offline
Old 09-27-2011, 08:58 AM
whitrzac's Avatar
why does it need to be a PDF in order to print? Just print it right from MS paint.
whitrzac is offline
Old 09-27-2011, 09:24 AM
FATKAT's Avatar
I work out in the field and i am sending the drawings back to the office by email. The office in turn gives the drawing to the electrician to go out and repair the lights I mark.
I am using all my equipment in my van (computer,printer, copier/scanner and wireless INTERNET access.) I do not know what the office has on their end and don't wish to make it hard for them to see and print my reports and I know they can easily print the PDF file on a 8.5 by 11 sheet of paper.
It freaked them out enough when they started getting my reports by email where every one else has to write them out by hand and deliver them by hand or find a place to fax them to the office. They couldn't figure out how I was doing it until I had to go to the shop and everybody wanted to see what I had set up. I even built my own laptop stand.
It seems that when I scan to a jpg it makes the file to large to print on one sheet of paper.
FATKAT is offline
Old 09-27-2011, 01:06 PM
pdf xchange viewer, man... im tellin ya
Old 09-27-2011, 09:56 PM
oXYnary's Avatar
Printer options: Fit to page. ???
oXYnary is offline
