Name one thing.... >
Name one thing....
Name one thing....
Old 11-25-2010, 12:09 PM
  #16
locked's Avatar
Originally Posted by Oasis View Post
Good ones..and care..I've had a few puff on me for no good reason..I take care of them, don't abuse them, use a good charger, balance them, and still for no reason..at least to me, go puff..
Do you ever leave them fully charged for more than a day?
locked is offline
Old 11-25-2010, 12:46 PM
  #17
Oasis's Avatar
Trader Rating: 38 (100%+)
Nope..I do take care of my batteries..I never let them discharge fully or overcharge them.
Oasis is offline
Old 11-25-2010, 01:12 PM
  #18
neobart's Avatar
All of the above.......well almost.
Paint, glue tires and drive. Two of those I hate doing.
neobart is offline
Old 11-25-2010, 01:26 PM
  #19
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Turnbuckles. I hate them bastards.
Dlewis4 is offline
Old 11-25-2010, 02:17 PM
  #20
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Soldering. More than half the time I can't get a solid connection. Sometimes it looks good, but then I get cogging or a wire pops right off. I completely destroyed the case for my RS pro from the iron slipping off the posts. It's been better since I bought a weller soldering gun, but I still suck at it.
Ill bet ya a hundred bucks you are just using the wrong kind of solder. Go to radio shack, get 60/40 rosin core solder, and all your weak solder joints go bye-bye... you can pay me whenever.
Cpt.America is offline
Old 11-25-2010, 02:38 PM
  #21
locked's Avatar
Yeah, you're probably right, but I was using rosin core solder from radio shack. I think it might have been cheaper stuff though. Initially the main problem was the iron I had wouldn't get hot enough to melt solder all the way through a 12 gauge wire. Now I have one that does it easily, but I think I do still need to get some better solder.
locked is offline
Old 11-25-2010, 03:06 PM
  #22
Trader Rating: 14 (100%+)
Yup....ruined another set of x-patterns. Gluing sucked so bad, tire looks like a square.
DuckStang is offline
Old 11-25-2010, 03:08 PM
  #23
GundamWZero's Avatar
Well I am impatient with painting at times... and i am definitely at hit and miss with tires. But I can drive once I get the lay of the track.
But the one thing that grinds my gears?
Stripped motor screws. At the heads and at the threads.
Also I despise cheaply made Allen Wrenches.
GundamWZero is offline
Old 11-25-2010, 06:17 PM
  #24
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Originally Posted by Jaz240 View Post
I cant drive!
Same here!
DOMIT is offline
Old 11-26-2010, 10:27 AM
  #25
boomgagem's Avatar
Trader Rating: 45 (100%+)
You losi guys will feel me....
After about 100 attempts, I've only managed to do it once.
Get all of the clutch pin screws out without stripping at least 1 head.
boomgagem is offline
Old 11-26-2010, 12:39 PM
  #26
Frozenshades's Avatar
Gluing tires can be hit and miss for me. Trimming new bodies just sucks.
Frozenshades is offline
Old 11-26-2010, 01:19 PM
  #27
roadkill's Avatar
Trader Rating: 145 (100%+)
this grinds my gears, punching body holes in a new shell. never get them just right,allways off just a bit.
roadkill is offline
Old 11-26-2010, 06:32 PM
  #28
jag5508's Avatar
Trader Rating: 15 (100%+)
Packing up at the end of the race day .
jag5508 is offline
Old 11-26-2010, 06:45 PM
  #29
Digit09's Avatar
only had that happen once, then switched to fioroni clutches. last forever and wont eat up bearings!!!
Digit09 is offline
Old 11-27-2010, 04:20 AM
  #30
Glueing tires. After three years I gave up and just use AKA pre-mounts.
The Working Man is offline
