Motor Oil?
Closed Thread
Old 09-27-2010, 01:33 PM
  #16
Suspended
Originally Posted by HOVERBOY26 View Post
Aaaand then you threw in the cooking oil comment. Do you recommend Wesson or Crisco?
Our little Glow diesels ran just fine on Castor Bean oil for years.
Storydude1 is offline
Old 09-27-2010, 04:45 PM
  #17
No one uses Amsoil, or Redline?
bshack is offline
Old 09-27-2010, 05:27 PM
  #18
Frozenshades's Avatar
Castrol GTX for my car
Frozenshades is offline
Old 09-27-2010, 06:24 PM
  #19
Digit09's Avatar
I prefer a chunk of hersey bar and a tea spoon of honey at every oil change. This helps with nothing and taste great too.
mobil 1 5000, change it every 4500 with filter. used Castrol for a long time, its good oil too. usually use a fram filter. also do a kerosine flush every 25 to 30,000 miles. really keeps the oil journals clean and helps oil delivery and pressure on high milage engines. I have nearly 180,000 miles on my 1994 camaro and it still runs in the low 12's on street tires and pump gas. All the "go fast" parts were installed with about 7000 miles on the car and it has lived a pampered but hard driven life since. just my 2 cents
Digit09 is offline
Old 09-28-2010, 11:59 AM
  #20
I change my mobile 1 every 3000 ish miles and filter. I don't really see the need to change it 5000 sounds to long to me
x60Driver is offline
Old 09-28-2010, 07:02 PM
  #21
kai888's Avatar
Trader Rating: 17 (100%+)
i have to change the oil in my car????
kai888 is offline
Old 09-28-2010, 11:29 PM
  #22
C_O_jones's Avatar
NO!, Your in Australia, down under, bottom half of the planet so all of your oil stays in the valve cover and never gets dirty.
C_O_jones is offline
Old 09-29-2010, 04:51 AM
  #23
redline for me.....z- 71 switched ALL fluids at 12000 miles. 10 k between oil changes filters at 3500. 150 k on the truck now and the vortec still gets 16 mpg on the highway,uses no oil and great power. 5w30 and still maintains 40 psi oil pressure when hot..hard to argue with that...
bpalmer is offline
Old 09-29-2010, 04:54 AM
  #24
Originally Posted by Storydude1 View Post
Whatever is 99 cents a quart at Vatozone.
Clean oil>brandname oil. Change it AND YOUR FILTER every 3000 and you could be running Cooking oil.
Most oil filters are in bypass by 2200 miles anyway. Once an engine is broken in, it doesn't produce much in the way of dirt and deposits. Flush the products made every 3K and they don't have a chance to accumulate.
i am sure the 99 cent filters are in bypass long before 2200
bpalmer is offline
Old 09-29-2010, 08:40 AM
  #25
Suspended
Please read my postings before replying. Kthnxbye.
Nowhere in that post do I say a 99 cent FILTER.
Old 09-29-2010, 11:24 AM
  #26
RCHR's Avatar
Regular Penzoil in my Honda Civic at 282,000 miles and rolling
RCHR is offline
Old 09-29-2010, 02:17 PM
  #27
Team Tekin
TY@TEAMTEKIN's Avatar
I run Amsoil Full synthetic and substitute a quart for Lucas Oil Stabilizer.
Which reminds me, the Teg is due for an oil change.
TY@TEAMTEKIN is offline
Old 09-29-2010, 02:57 PM
  #28
Teg? Intregera?
Old 09-29-2010, 03:18 PM
  #29
Trader Rating: 33 (100%+)
Fun times right here.
marooko is offline
Old 09-29-2010, 07:21 PM
  #30
Amsoil or Rediline once a year with spectrum analysis. The oil samples have proved that once a year is fine!
bshack is offline
