Do people use brake? >
Old 06-03-2010, 08:52 PM
05forfun's Avatar
Trader Rating: 81 (100%+)
Default Do people use brake?
I am wondering if people use brake function before entering the corners, or most of time they just use drag brake (neutral brake) to slow down the car. From my observation, it seems depending on personal preference and driving style
05forfun is offline
Old 06-03-2010, 08:57 PM
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
i usually set my drag brake up to do most of my braking but i will use the actual brakes on tight corner (or if i blow my line) and at the end of long straights
RaceAce701 is offline
Old 06-03-2010, 09:02 PM
the sponsored drivers at my track uses drag brake only. i asked one of them why and they said for two reasons. one was because it takes more time to go from full throttle to neutral to brake and those tenths of seconds adds up, and the second was it unsettles the car. i still use brakes, but thats cuz I used to run nitro alot so I havent changed yet.
ncode is offline
Old 06-03-2010, 09:08 PM
05forfun's Avatar
I never used actual brake in the race and it seemed my car was pretty good most of time, but never caught up with some A main guys. I think in addition to the skills, using actual brake at some particular points may help people go around the corner faster and have quicker lap time as well
05forfun is offline
Old 06-03-2010, 10:12 PM
kschu's Avatar
Trader Rating: 16 (100%+)
i use actual brake all the time before entering corner..this allow me to point ,shoot and brake..
kschu is offline
Old 06-03-2010, 10:43 PM
Oasis's Avatar
Trader Rating: 38 (100%+)
I use brakes on tight tracks..depending on the corners, I have Never used drag brake..and I was a sponsored driver..just like most have said..depends on track and what your running..diff, spool, oneway..oneway..never, diff and spool yes..
Oasis is offline
Old 06-04-2010, 06:55 AM
When I use brakes its usually just a small blip of the brake just to slow the car down enough to make the corner, but I only race in 17.5. My main straight is 2 1/2 tennis courts long with a hairpin turn at the end.
Scooter79rs is offline
Old 06-04-2010, 08:00 AM
drive2survive's Avatar
Trader Rating: 23 (100%+)
good to see this post and have been wondering about it,after a year have figured out feathering/manual braking plays a big part on tight tracks but have also noticed that split second can lose a race when the other guy flys around ya, good technek to develope
drive2survive is offline
Old 06-04-2010, 08:40 AM
Digit09's Avatar
are you refering to electric or nitro? on or off road? mainly, I use the brakes for changing the attitude of a vehicle in the air. less time spent going up, is more time spent going forward!!!
Digit09 is offline
Old 06-04-2010, 10:49 AM
joe of loath's Avatar
I set drag brake to 0 and still don't use brake. I just coast into the corner, it saves on battery power. (Am still running ni-mh)
joe of loath is offline
Old 06-05-2010, 07:05 AM
RCAKid's Avatar
i dont use drag break at all and for my breaks i use verry little if your car is set up good the car should rotate through the turns with out losing much speed.
RCAKid is offline
