why top driver donīt use 2,4G? >
Old 12-30-2008, 05:11 PM
Bill-CZ's Avatar
Questions?? why top driver donīt use 2,4G?
Iīm looking for KO PROPO 2.4G Fast Response Module And Receiver... but iīm not sure if it is faster then normal...
Bill-CZ is offline
Old 12-30-2008, 05:53 PM
Andrew_Carter's Avatar
I spoke to Adam Skelding about this at the weekend,he said the KO system was just as fast as his old 40mhz setup!
Andrew_Carter is offline
Old 12-30-2008, 06:37 PM
RCSteve93's Avatar
For international Pro racers, sometimes it is not legal in some countries. So for those top pro racers that travel, it would be a PITA to use 2.4ghz then get to a country that doesn't allow it, and your screwed.
RCSteve93 is offline
Old 12-30-2008, 09:39 PM
yep.. some countries and/or events don't allow the use of 2.4Ghz.
Minami is offline
Old 12-30-2008, 11:05 PM
Trader Rating: 22 (100%+)
Default Frequency
I guess the pros would have to have a variety of frequencies available. In Australia 75 and 40 meg are not legal. Everyone uses 27, 29mH and 2.4gig
Terry
Team Ash is offline
Old 12-31-2008, 01:53 AM
Losiho's Avatar
Terry
40Mhz is legal in Oz, in addition to 27Mhz and 29Mhz.
Losiho is offline
Old 12-31-2008, 02:19 AM
Default Oh well.
My mistake, sorry. Memory isn't what it used to be.
27,29,36,40 and 2.4 gig are all legal in Australia.
Team Ash is offline
Old 12-31-2008, 08:39 AM
jag88's Avatar
Be aware that the KO 2.4G doesn't work when a Futaba 4PK in turned on.
I posted this problem in their thread and their response was, "Ask those that are using the 4PK to switch to the French mode, this opens up the lower band for others systems to bind."
Also, "send it in for repairs."
Prior to this, KO made no mention of this problem on their website or on this forum.
jag88 is offline
Old 12-31-2008, 08:48 AM
Trader Rating: 16 (94%+)
2.4GHz is really just a convenience thing, not a racer development. It does not make a driver faster, and since the majority of top drivers practice in off-peak times at their local tracks, and then race at controlled events, plus race at races round the world, what advantage would 2.4GHz give a top driver??
It also goes to show that these $300+ new radios are not going to make you a better driver if you already own a quality radio.
kn7671 is offline
Old 12-31-2008, 11:14 AM
Up to about a month ago I was still using AM. I was pretty happy with my setup, but it is hard to find AM stuff anymore. I bought a new 2.4 radio and have not noticed anything different between the two. I still have not upgraded the rec. in all of my cars yet so my mini, 1/12, buggy... are still at AM.
I bounced receivers back and forth to see if I could tell a difference and could not. In my book the big reason for 2.4 is you don't have to worry about someone stepping on you.
All of my planes and heli's are still on FM. I don't plan on changing them till I can't get FM stuff any longer.
cherokee is offline
Old 12-31-2008, 11:21 AM
05forfun's Avatar
Trader Rating: 81 (100%+)
I agree even though I have never owned any 2.4GHz radio. I just somethings doubt about how quick the response you can physically feel. Some manufacturers claim their new gears can decrease response time, but can people really tell that 0.01s difference? Maybe some top racers do
05forfun is offline
Old 12-31-2008, 03:08 PM
AdrianM's Avatar
The pros can feel some lag under the most critical conditions...like foam tire carpet racing. Not all 2.4 system have lag. The Spektrum DX3R and the new DX3S are just as fast as normal radios. These radios encode the analog signals from the steering and trigger pots directly into DSS.
Radios with modules encode anaglog to pulse point (FM PPM) then to DSS. THAT is where the lag comes from. I know Airtronics and KO radios are like this. Futaba's 2.4 non module radios might be like the top Spektrum radios.
Normal FM radios encode anaglog to PPM and all the module does is assign a transmission freq so they are very fast.
AdrianM is offline
Old 12-31-2008, 03:15 PM
Pooh2's Avatar
I'm a gas racer and I can tell u, 2.4 has lag. I don't like the delay and don't use them. I know some racers will say it has no lag but it really does. U think that u get used 2 it until u go back 2 crystals.
Pooh2 is offline
Old 12-31-2008, 03:26 PM
over gear's Avatar
Trader Rating: 16 (100%+)
does 4PK work when a KO 2.4G is turned on??
over gear is offline
Old 12-31-2008, 03:52 PM
jag88's Avatar
Yes
jag88 is offline
Copyright Đ 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
