How to archive? >
How to archive?
Like Tree2Likes
  • 1 Post By OffRoadJunkie
  • 1 Post By Diana
How to archive?
Old 01-04-2021, 08:46 PM
Default How to archive?
I work for a car dealership where I work as an accountant. Our dealership has also a website where every information is provided and we mostly communicate via mails. The question is how to archive such mails. I guess it's the wrong forum to ask this but I need to archive those emails.
Diana is offline
Old 01-05-2021, 06:42 AM
Hi Diana. Yea you're definitely in the wrong forum for this.
It all depends on the email client you're using. If you open your email there's usually a help section where you can search for help on archiving. Or hopefully your dealership has an IT department. Your best bet is to ask them. Good luck!
jiml is offline
Old 01-05-2021, 06:59 AM
Roelof's Avatar
Would not supprise me if the topicstarter does nothing with RC
Roelof is offline
Old 01-05-2021, 07:45 AM
mrreet2001's Avatar
It looks like they are post running.
mrreet2001 is offline
Old 01-05-2021, 11:47 AM
So I'm an eternal optimist
jiml is offline
Old 01-05-2021, 12:00 PM
OffRoadJunkie's Avatar
Well,
In case you come back to check on this. Technically you're in the wrong forum, but then again, the is the Basement so everything goes.
I'm sure you're using Outlook for your emails. If so, you will need to go into File Explorer on your computer. Click on Documents, on the left, and create a file called Emails. In that file, you can create as many other files as you needed to help separate where the email came from. Go you the email you want to save and click on File in the top left corner of the screen. Then click on Save As then save it to the file you want to save it in. After you save the email to your file, you can delete in from your email inbox.
If you're not using Outlook, that might be okay because this is the same process for most email providers.
If you are looking for archive emails, then that is something your IT department will have to help you with. Each company will have a different internal settup.
Diana likes this.
OffRoadJunkie is offline
Old 01-05-2021, 01:10 PM
Roelof's Avatar
Prrrfff... creating mailfolders is the best way and can be done in any mail client, in outlook they are called PST files, in the manu it is called "create data file"
https://support.microsoft.com/en-us/...2-f331f60e2790
Roelof is offline
Old 01-05-2021, 05:54 PM
That way also works. The way I explained will save the files to your computer where you can then move it to external hard drive.
Old 01-05-2021, 11:35 PM
Roelof's Avatar
PST files you can also backup to other drives
Roelof is offline
Old 01-12-2021, 05:57 AM
I found the solution here
reddit.com/user/International_Leg573/comments/ksc1wg/how_to_archive_mails/
jiml likes this.
Diana is offline
Old 01-25-2021, 10:42 PM
I was looking for this info thanks for telling,
Jordanwills35 is offline
Old 01-25-2021, 10:43 PM
Nice article buddy
