Product information.
Old 05-14-2006, 08:01 AM
Default Product information.
We are starting this new thread to give information about the product we are selling.
We will start with Flap series of traction compound first.
There's 4 kinds of Flap traction compound right now.
Flap gripper, wheel sucker, road cling and Magic drop.
Flap Gripper: Good for outdoor, doesn't change the tires compound. Best to apply it 10 to 20 mins before race. Will not soak into the tires so much, only on the outer layer.
Road Cling: Good for indoor. Will soften the tires, changing the tires compound.
Wheel sucker: Between Flap Gripper and Road Cling. Best to use with tire warmer.
Magic Drop: Use to mix with traction compund, to help them soak into the tires faster.
Informations from the Mr Muzuuchi (Flap boss).
Fujio is offline
Old 05-17-2006, 11:21 PM
Default TA05 Aluminium Bulkhead.
For TA05 Aluminium Bulkhead we have both upper and lower ones from Xenon and Square.
For the lower one both brand look about the same but the Square ones is closer to Tamiya blue.
The Xenon one colour is abit too light. But Square one is slightly more expensive.
Xenon lower bulkhead Discounted price is 2923Yen
Square lower bulkhead Discounted price is 3276Yen
Personal recomandation: Square ones as it look nicer, will match better with Tamiya option parts. But if the Xenon one is the same colour as Square I will pick Xenon(cheaper).
For upper bulkhead the Xenon one is 2 piece and the Sqaure one is one piece bulkhead.
So Xenon one is more lightweight but Square ones will be more precise.
Xenon upper bulkhead Discounted price is 2503Yen
Square upper bulkhead Discounted price is 3864Yen
Personal recomandation: Will choose Square too as I like my car to look nice(Lousy drivers like me, can't drive fast never mind but car must look nice).
Fujio is offline
Old 05-27-2006, 07:10 AM
Shop Owner
Default Special Differential ball Set.
Champ Racing Products
These are very high grade steel diff balls, engineered specially for high precision applications. One of the roundest that you can get. Thus providing your differential with very smooth rotation. These are what most pro drivers are using in Japan since long time ago.
Avaliable in 3mm (Tamiya) and 3/32" (HPI and Yokomo).
Also we have MATCHED ones too which specially matched for even higher tolerance. These will make you differential super smooth.
Avaliable in 50 or 100 pieces.
High grade 3mm balls (50 pieces) Discounted price 504Yen
High grade 3mm balls (100 pieces) Discounted price 924Yen
Matched High grade 3mm balls (50 pieces) Discounted price 1260Yen
Matched High grade 3mm balls (50 pieces) Discounted price 2352Yen
High grade 3/32" balls (50 pieces) Discounted price 504Yen
High grade 3/32" balls (100 pieces) Discounted price 924Yen
Matched High grade 3/32" balls (50 pieces) Discounted price 1260Yen
Matched High grade 3/32" balls (50 pieces) Discounted price 2352Yen
This lots were choosen from millions, and we only have limited quantities,
especially the Matched ones.
To order please email to [email protected]
Masa is offline
Old 06-21-2006, 05:12 AM
Default KOSE Bearing Checking Tool
K-9041 Kose Bearing Tools
This tools is good for testing bearings of different size.
From 2(Mini-Z bearings), 3, 4, 5, 6, 8, 10, 12 and 14mm(for engine car bearings) diameter.
You can easily tell the condition of your bearings with this tool.
Avaliable in Tamiya blue, purple and black.
Discounted price 840Yen.
A very cheap and good tool to have.
Fujio is offline
Old 06-21-2006, 10:09 PM
akuhon's Avatar
My suggestion -> just my 2 cent. (I have one already) :
1. Make the cover of this tool with steps also, so we know not only the inside dia. but also the outside dia. of the bearing. As for the material, it can be anything, but make sure it's transparent, so the size can be seen easily (inside and outside dia.) when we cover the bearing. Please don't use just those plastic tubing.
2. Please put the number on each step so the user know what's the bearing size immediately.
You can tell to Kose people Fujio, since I can't speak Jap....
nb. credit my name if Kose follow my suggestion (just kidding - no need)
akuhon is offline
Old 06-21-2006, 10:42 PM
akuhon: Thank you for your suggestion. But I don't think both ideas will be good.
1.) If they make a cover for outside dia, then this tool will look like a mushroom and difficult to keep in tool box.
2.) It's not easy to put the number at the rounded surface. If they do that I don't think it will be cheap.
Fujio is offline
Old 06-22-2006, 08:30 PM
akuhon's Avatar
Ok, here's my other 2 cent (so total will be 4 cent so far ..... )
For :
no.1. If you think it'll be big.... make it small... Small / compact is a beautiful thing. To make it compact, please make it retractable just like the TX antenna. Of course, the length should be much..much shorter. The smallest hole should be the same as the smallest hole on the bearing tool.... i.e 2mm dia.
The largest hole, you can judge by yourself which one is most common outer side for bearing size on the market for nitro and electric.
No.2. engraving tool can be use in many kind of surface .... even on a ball shape... I think it's not expensive.... IMO
Maybe Champ can make this product....
That's all Fujio....
akuhon is offline
Old 06-23-2006, 07:01 AM
akuhon: Thank you for your input.
Fujio is offline
