Go Back  R/C Tech Forums > North American Regional Forums > Canadian R/C Scene
Overgeared Racing Presents 2017 "Big Chill" November 3, 4, 5 >
Like Tree32Likes
Old 08-27-2017, 08:02 PM
eevul's Avatar
Thumbs up Overgeared Racing Presents 2017 "Big Chill" November 3, 4, 5
Big Chill returns for the 2017 Season
https://goo.gl/maps/hCJRg
Track will be open Friday from 3pm to 9pm for practice. Early registration will be from 7pm to 8:30pm on Friday evening. The doors will open at 7-9am for practice and registration on Saturday. Registration will close at 8:30am with a drivers meeting at 9:15am. Qualifying will begin at 9:30am sharp. For Sunday, doors will be open at 7am for practice. Last chance qualifying will begin at 9am sharp but time may be pushed to 8am depending on number of racers. We should hopefully be done around 3 to 4pm but this again depends on the number of entries.
New for this year, CRC black carpet
Yes, that's right! The OGR crew is very happy to announce that we have purchased CRC black carpet and will be running that for the Big Chill moving forward!
Classes include
• Touring Stock 17.5
• Touring Modified
• 1/12th scale 13.5
• 1/12th scale Modified
• Formula 1 Rubber 21.5
• Big Block Scale Spec 21.5
• Tamiya Euro TruckEuro Semi-Truck GT
All races are 5 minutes in duration with the exception of the 1/12th Scale cars at 8 minutes.
Tech inspection…Battery voltage will be checked before the race. Must be at 4.200000000 volts per cell or below. Ride Height and weight will also be checked before the race.
Drivers are required to corner marshal after their race. If they cannot marshal they are required to find their own replacement and inform the Race Director. If the Race Director finds a driver/substitute not corner marshaling, their previous qualifier will be docked 1 complete lap.
There will be a Spec Tire for Touring Stock and Modified…. Tires are Gravity G Spec Type C. Tires will be available for purchase at the track from Overgeared and will be marked per class. The tires will be between $35-40 Price will be based on US exchange at the time...as close to $35 as we can get. 1 set of tires will be checked in for the weekend for TC stock and 2 sets for TC Mod. Each class will require its own set of tires.
Touring Super Stock presented by About RC Racing - ORCA
Motor: 17.5 Brushless motor ROAR Approved
ESC: (BLINKY) No ESC timing or boost.
Battery: 2S Li-po hard case batteries only
Tires: Gravity G-Spec - 1 Set to be purchased at the track and marked
Weight: Minimum weight 1350g
Bodies: Top of wing on touring cars must be equal to or below the roof-line in race ready position.
Ride Height - 5mm minimum
Touring Modified Presented by options-rc
Motor: Open
ESC: Open ESC
Tires: Gravity G-Spec - 2 Sets (maximum) to be purchased at the track and marked
Bodies: Top of wing on touring cars must be equal to or below the roof line in race ready position.
Ride Hight - 5mm minimum
12th Stock Presented by Gravity RC
Motor: Roar Approved 13.5
ESC: (Blinky)No ESC timing or boost.
Battery: 1S Li-po hard case batteries only
Tire – Lilac Spec Tire Must Have purple stripe
Weight: Minimum weight 730g
Bodies: 1/12 cars must run Can-Am/Lola style bodies.
Ride Height - 3mm minimum
NOTE: 12th stock can use the JFT blue strip tires. Available through OverGeared at $25 set of 4.
12th Modified Presented by GripworksRC.com
Motor: Open
ESC: Open
Open Tire
R/C Big Block Scale Spec Presented by RC Pit Stop
Motor: Any 21.5 Open Gearing
ESC: (Blinky) No ESC timing or boost.
Tires: VTA Spec / HPI D Compound or Gravity R/C USGT Spec Tires
Weight: Minimum weight 1400g 4WD / 1200g for FWD (front wheel drive)
Bodies: anything scale appearing with fenders but not a touring body.
Formula 1 Presented by Hi Performance Distributors
Motor: 21.5 or Silver Can
ESC: (Blinky) No ESC Timing or Boost
Tires: Rubber Only
Minimum weight: 1050g
Body: F1 style with Moulded Wings. No Lexan Wings.
Width – Maximum 190mm
Ride Height - 4mm minimum
Euro Semi-Truck GT Presented by Go Go Hobbies
This is a pure box stock class open to any skill level hobbyist.
1. Legal kits: Item 58632 RC Team Hahn Racing MAN TGS (TT-01 type E chassis) &
Item 58642 RC Team Reinert Racing MAN TGS (TT-01 type E chassis)
2. The kit must be built exactly per the instruction manual.
3.(( The ONLY Hop-Op Option permitted is Ball Bearings.)
4. Must use stock pinion and spur gear.
5. The kit Tamiya TBLE-02S ESC and kit supplied motor (item 54358 RS-540 Torque Tuned Motor) must be used. Battery connector may be changed to DEANS. Motor
Bullet connectors may not be removed.
6. All body parts must be used.
7. Body may be painted in any scheme.
8. Must use kit tires and wheels. Kit tires may be glued onto wheel.
9. Any grease or lube may be used to lubricate gears or moving parts.
10. Batteries: Any hardcase LiPo battery max capacity 6200 MAH may be used for this class.
Please note that we may update the rules as the date gets closer to better match what is currently being run.
Race Fees
$50 1st class
$20 2nd class
$10 3rd class
$5 4th class
Hotels
Closest to Furthest
Best Western Rainbow Country Inn(<5 minutes)
43971 Industrial Way
Chilliwack, BC
V2R 3Z9
604-392-4667
WCICS Discount code (Thank You Josh and WCICS.CA)
01524140 use when calling or booking at bestwestern.ca
Hampton Inn by Hilton Chilliwack(<5 Minutes)
8050 Lickman Rd
Chilliwack, BC
V2R 3Z9
(604) 392-4667
Comfort Inn(10 Minutes)
45405 Luckakuck Way
Chilliwack, BC
V2R 3C7
(604) 858-0636
Travelodge Chilliwack Hotel(10 minutes)
45466 Yale Rd W
Chilliwack, BC V2R 3Z8
(604) 792-4240
Coast Chilliwack Hotel(15 minutes)
45920 First Avenue
Chilliwack, BC V2P 7K1
(604) 792-5552
Chilliwack Heritage Park also may offer the opportunity to camp in their parking lot with an electrical hookup. We'll check into the price and post it once we have the info. You must let OGR know before race weekend so that we can register you with the Heritage Park if you are interested in this.
If you have any questions, please let us know as soon as possible.
eevul is offline
Old 08-27-2017, 11:43 PM
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
Reserved post
R3VoLuTiOn is offline
Old 08-28-2017, 07:01 AM
BPRacing's Avatar
Count me and Mason in! Looks like mini didn't make the cut this year? Sign us both up for Scale Spec please.
BPRacing is offline
Old 08-28-2017, 07:20 AM
eevul's Avatar
Mini barely made the cut last year due to low turn outs. I'm sure that if we get enough requests for it, we can look at adding the class back in.
eevul is offline
Old 08-28-2017, 08:17 AM
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Pretty excited for you guys with the new acquirement! Tim started hounding me months ago; we are going to the Chill again, right? Yes Tim, we can go again! With as much travel racing everyone is doing lately, guys are going to need to apply for a CanAm Citizenship. Maybe even a Nexus pass and zip right through.
Tiny! Get yourself well buddy.
Brian
Slapmaster6000 is offline
Old 08-28-2017, 08:57 AM
BPRacing's Avatar
Works for me. If it gets added Mason will run that also.
BPRacing is offline
Old 08-28-2017, 09:33 AM
Trader Rating: 20 (100%+)
Cole & I should make it (fingers crossed), Cole would also run mini if it's a go
kchura is offline
Old 08-28-2017, 06:57 PM
Tiny.24's Avatar
Brian
Thanks Brian... down but not out. Can't wait to get the Nortwest and Westcost Carpet Family together again. The Overgeared Team is full speed ahead even with me down...
Tiny.24 is offline
Old 08-28-2017, 07:47 PM
tpczx6's Avatar
Flights book, new 1/12 scale shipped out today,time off from work put in-and looking to find some tires for 1/12 spec
Tiny I have a good amount of pro one spec tires they are mounted from BSR so they should be ok? if not I will find others
Tim
tpczx6 is offline
Old 08-28-2017, 08:50 PM
Tiny.24's Avatar
Tim
As soon as they jail break me Seattle RC Racers will be getting their JFT Tires. Or Overgeared will have them on location...
Tiny.24 is offline
Old 08-28-2017, 08:57 PM
SLOWINSLOWOUT's Avatar
Are JFT specs going to be the only tire? Or can we also use CRC/Jaco?
SLOWINSLOWOUT is offline
Old 08-28-2017, 09:33 PM
Tiny.24's Avatar
Any of the spec tires. But the JFT tire sales benefit the home club by being less expensive there by promoting the class
Tiny.24 is offline
Old 08-29-2017, 01:41 PM
Tiny.24's Avatar
We've been put on floor 1 at Chilliwack Heritage Park. Power is drawn from limited plug ins. Be sure to bring your own power strip. Possibly bring an extension chord.
Tiny.24 is offline
Old 08-29-2017, 05:07 PM
durtbag's Avatar
Maybe mini needs a change in spec or speed on large tracks? It might bring some out of the basement.
Maybe 13.5 blinky, SWB, open tire.
Fast guys might even pick up a used chassis for that kind of entertainment.
durtbag is offline
Old 08-29-2017, 06:41 PM
(0000000000)'s Avatar
Tamiya truck appears to be the new mini.
T.Wilks191 likes this.
(0000000000) is offline
