Overgeared Racing Presents 2016 "Big Chill" November 4,5,6
Big Chill returns for the 2016 Season
https://goo.gl/maps/hCJRg
Track will be open Friday from 3pm to 10pm for practice. Early registration will be from 7pm to 9pm on Friday evening. The doors will open at 7-9am for practice and registration on Saturday. Registration will close at 8:30am with a drivers meeting at 9:15am. Qualifying will begin at 9:30am sharp. For Sunday, doors will be open at 7am for practice. Last chance qualifying will begin at 9am sharp but time may be pushed to 8am depending on number of racers. We should hopefully be done around 3 to 4pm but this again depends on the number of entries.
Classes include
• Touring Stock 17.5
• Touring Modified
• 1/12th scale 13.5
• 1/12th scale Modified
• Formula 1 Rubber 21.5
• Big Block Scale Spec 21.5
• Spec Mini 21.5
All races are 5 minutes in duration with the exception of the 1/12th Scale cars at 8 minutes.
Tech inspection…Battery voltage will be checked before the race. Must be at 4.200000000 volts per cell or below. Ride Height and weight will also be checked before the race.
Drivers are required to corner marshal after their race. If they cannot marshal they are required to find their own replacement and inform the Race Director. If the Race Director finds a driver/substitute not corner marshaling, their previous qualifier will be docked 1 complete lap.
There will be a Spec Tire for Touring Stock and Modified…. Tires are Sweeps 32s. Tires will be available for purchase at the track from Overgeared and will be marked per class. The tires will be between $35-40 Price will be based on US exchange at the time...as close to $35 as we can get. 1 set of tires will be checked in for the weekend for TC stock and 2 sets for TC Mod. Each class will require its own set of tires.
ORCA Touring Stock presented by About R/C Racing
Motor: 17.5 Brushless motor ROAR Approved
ESC: (BLINKY) No ESC timing or boost.
Battery: 2S Li-po hard case batteries only
Tires: Sweeps QTS 32s- 1 Set to be purchased at the track and marked
Weight: Minimum weight 1350g
Bodies: Top of wing on touring cars must be equal to or below the roof-line in race ready position.
Ride Height - 5mm minimum
Pro Spec America Touring Modified
Motor: Open
ESC: Open ESC
Tires: Sweeps QTS 32s- 2 Sets (maximum) to be purchased at the track and marked
Bodies: Top of wing on touring cars must be equal to or below the roof line in race ready position.
Ride Hight - 5mm minimum
GoGo Hobbies 12th 13.5
Motor: Roar Approved 13.5
ESC: (Blinky)No ESC timing or boost.
Battery: 1S Li-po hard case batteries only
Tire – Lilac Spec Tire Must Have purple stripe
Weight: Minimum weight 730g
Bodies: 1/12 cars must run Can-Am/Lola style bodies.
Ride Height - 3mm minimum
Apexrc.com 12th Modified
Motor: Open
ESC: Open
Open Tire
R/C Pit Stop Big Block Scale Spec
Any on-road 1/10th scale RC vehicle 1450 for 4wd 1250 for Front wheel drive
Motor: Any 21.5 Open Gearing
ESC: (Blinky) No ESC timing or boost.
Tires: HPI VTA Spec/ HPI D compound or Gravity R/C USGT Spec Tires
Weight: Minimum weight 1450g 4WD / 1250 for FWD (front wheel drive)
Bodies: anything scale appearing with fenders but not a touring body.
Gripworksrc.com Formula 1
Motor: 21.5 or Silver Can
ESC: (Blinky) No ESC Timing or Boost
Tires: Rubber Only
Minimum weight: 1050
Body: F1 style with Moulded Wings. No Lexan Wings.
Width – Maximum 190mm
Ride Height - 4mm minimum
Franko Roberts Racing Mini Spec
Chassis - Any Tamiya M Chassis car - Assembled as per instruction manual. (IE: No FWD to RWD M-03 conversions)
Unnecessary parts may be left off during assembly (IE: rolls bars on M-05, electronics trays) but no part may be sawed, cut, or milled from chassis.
Drive train - Open Diff and Drive train, maintaining the kit FDR. 16, 18 and 20 tooth pinions in M-03/M-05/M-06. 17 and 19 tooth pinion only in M-04. 21 tooth pinion not permitted.
Hop Ups - All other Tamiya or aftermarket hop ups are permitted.
ESC – any ESC in BLINKY mode or brushed ESC
Motor – Any 21.5 , Orca 2200kv(or Equivelant) Silver Can Brushed Motor
Wheels/Tires - Tamiya branded mini sized tires and inserts only. Double stuffing not permitted. Any mini sized wheel.
Bodies - Open to any mini sized body with the following restrictions - No touring sedan and/or 12th scale type wedge/Can Am bodies. Bodies must be cut and painted along the factory body lines.
Battery - Any 2S, 7.4V, (without modification to pack or chassis)
Minimum Weight - 1200g
Please note that we may update the rules as the date gets closer to better match what is currently being run.
Race Fees
$50 1st class
$20 2nd class
$10 3rd class
$5 4th class
Hotels
Closest to Furthest
Best Western Rainbow Country Inn(<5 minutes)
43971 Industrial Way
Chilliwack, BC
V2R 3Z9
604-392-4667
WCICS Discount code (Thank You Josh and WCICS.CA)
01524140 use when calling or booking at bestwestern.ca
Hampton Inn by Hilton Chilliwack(<5 Minutes)
8050 Lickman Rd
Chilliwack, BC
V2R 3Z9
(604) 392-4667
Comfort Inn(10 Minutes)
45405 Luckakuck Way
Chilliwack, BC
V2R 3C7
(604) 858-0636
Travelodge Chilliwack Hotel(10 minutes)
45466 Yale Rd W
Chilliwack, BC V2R 3Z8
(604) 792-4240
Coast Chilliwack Hotel(15 minutes)
45920 First Avenue
Chilliwack, BC V2P 7K1
(604) 792-5552
Chilliwack Heritage Park also may offer the opportunity to camp in their
parking lot with an electrical hookup. We'll check into the price and post it once we have the info. You must let OGR know before race weekend so that we can register you with the Heritage Park if you are interested in this.
If you have any questions, please let us know as soon as possible.
Classes include
• Touring Modified
• 1/12th scale 13.5
• Spec Mini 21.5
Motor: Open
ESC: Open ESC
Motor: Open
ESC: Open
Open Tire
Tires: Rubber Only
Race Fees
$50 1st class
$20 2nd class
$10 3rd class
$5 4th class
Hotels
Closest to Furthest
Chilliwack, BC
V2R 3Z9
604-392-4667
8050 Lickman Rd
Chilliwack, BC
V2R 3Z9
(604) 392-4667
45405 Luckakuck Way
Chilliwack, BC
V2R 3C7
(604) 858-0636
45466 Yale Rd W
(604) 792-4240
45920 First Avenue
(604) 792-5552
Last edited by eevul; 11-03-2016 at 08:27 PM. Reason: Updated classes, times and tires for MOD/Stock TC, race fees
I was just talking about this race at supper with my wife. Hoping to make the drive down from Edmonton for it.
Should be a great race as always!!!!
Following!
Will be excellent for sure!!!
Jesse are you back in Vancouver?
We will be doing pre registrations to secure your tires.
Limited tires will be in hand to cap the entries for stock and mod.
Stock touring, 1 set of tires will be allowed.
Mod touring will have the option of 2 sets of tires.
