Go Back  R/C Tech Forums > North American Regional Forums > Canadian R/C Scene
Overgeared Racing 2016/17 Winter Season - Vancouver Indoor Onroad >
Like Tree10Likes
Old 05-01-2016, 05:17 PM
eevul's Avatar
Default Overgeared Racing 2016/17 Winter Season - Vancouver Indoor Onroad
We have already secure the following dates for next indoor onroad season so here they are:
Winter Season 2016/17
October 1,22
November 4,5,6 Big Chill @ Chilliwack Heritage Park, 19
December 10
January 14,28
February 11,25
March 11,25
April 1,8,22
All dates except Big Chill will be held at our home venue Peace Mennonite Church
11571 Daniels Rd Richmond BC
Doors will be open for track setup this season to start at 6am with practice to follow. The quicker the setup, the more practice time there will be. Registration will open at 9:15 and close at 10am. Drivers Meeting at 10:20 First round begins at 10:30am. We will plan for 3 rounds of qualifying based on entries and Single Mains. Our Scheduled end time is 6PM. We must be cleaned up and out by this time.
Classes include (Rules to follow)
• Touring Stock 17.5
• Touring Modified
• World GT 10.5 (tentative)
•1/12th scale 13.5
• 1/12th scale Modified
• Formula 1 Rubber 21.5
• Tamiya Mini Spec (tentative)
• Big Block Scale Spec 21.5
All races are 6 minutes in duration with the exception of the 1/12th Scale cars at 8 minutes.
Sweep QTS Spec Tires are required to be eligible for the 2016/17 Season Points Series for the Touring Classes
Spec Mini
Chassis - Any Tamiya M Chassis car - Assembled as per instruction manual. (IE: No FWD to RWD M-03 conversions)
Unnecessary parts may be left off during assembly (IE: rolls bars on M-05, electronics trays) but no part may be sawed, cut, or milled from chassis.
Drivetrain - Open Diff and Drivetrain, maintaining the kit FDR. 16, 18 and 20 tooth pinions in M-03/M-05/M-06. 17 and 19 tooth pinion only in M-04. 21 tooth pinion not permitted.
Hop Ups - All other Tamiya or aftermarket hop ups are permitted.
ESC – any ESC in BLINKY mode or brushed ESC
Motor – Any 21.5, Orca 2200kv(or Equivelant) Silver Can Brushed Motor
Wheels/Tires - Tamiya branded mini sized tires and inserts only. Double stuffing not permitted. Any mini sized wheel. We won’t stop other tires from being run However to be eligible for the 2015/16 Points Series Tamiya Branded tires must be run.
Bodies - Open to any mini sized body with the following restrictions - No touring sedan and/or 12th scale type wedge/Can Am bodies. Bodies must be cut and painted along the factory body lines.
Battery - Any 2S, 7.4V, (without modification to pack or chassis)
Minimum Weight - 1200g
Ride Height - 3mm minimum
Touring Stock 17.5
Motor: 17.5 Brushless motor ROAR Approved
ESC: (BLINKY) No ESC timing or boost.
Battery: 2S Li-po hard case batteries only
Tires: Sweep Spec Tires QTS 32- Any Tire is allowed but will not qualify for the points Series
Weight: Minimum weight 1350g
Bodies: Top of wing on touring cars must be equal to or below the roof-line in race ready position.
Ride Height - 5mm minimum
Touring Modified
Motor: Open
ESC: Open ESC
Bodies: Top of wing on touring cars must be equal to or below the roofline in race ready position.
Ride Hight - 5mm minimum
World GT 10.5
Motor: 10.5 Brushless motor
ESC- ( Blinky)No ESC timing or boost.
Battery: 1S Li-po hard case batteries only
Tires: WGT Spec tires
Weight: Minimum weight 930g
Maximum width 200 mm
Bodies: World GT spec bodies only
Ride Height - 4mm minimum
Any on-road 1/10th scale RC vehicle FWD cars will follow the same rules and weight
Motor: Any 21.5 Open Gearing
ESC: (Blinky) No ESC timing or boost.
Tires: HPI VTA Spec/ HPI D compound or Gravity R/C USGT Spec Tires
Weight: Minimum weight 1450g
Bodies: anything scale appearing with fenders but not a touring body.
Formula 1
Motor: 21.5 or Silver Can
ESC: (Blinky) No ESC Timing or Boost
Tires: Rubber Only
Minimum weight: 1050g
Body: F1 style with Moulded Wings. No Lexan Wings.
Width – Maximum 190mm
1/12 Stock 13.5
Motor: Roar Approved 13.5
ESC: (Blinky)No ESC timing or boost.
Tire – Open Tire to allow for use of existing stock of tires (Gentleman’s Agreement to run WGT Style Spec Tire) Mandatory next season
Weight: Minimum weight 730g
Bodies: 1/12 cars must run Can-Am/Lola style bodies.
1/12 Open
Motor: Open
ESC: Open
Open Tire
Minimum 4 Cars for the Class to run… (we need minimum 4 Marshals for the next race)
Classes will be combined only if the majority of the racers in the combined Classes agree to it in a Live Vote
Doors will open at 6am with Setup commencing immediately. Practice will begin when the track is 100% complete. Many Hands Makes Light Work. Registration will open at 8:30 and Close at 9:30… a 5 minute warning will be given. If not registered by 9:30 you will miss the first round. If you are going to be late TEXT someone to add you into your required class and a spot will be kept in the lineup for you. Pay an OGR Board Member when you Arrive….
A general drivers meeting will be called at 9:45… please ask any questions and address any issues during this time….
Races will begin 5 Min after the completion of the Drivers Meeting.
We are expecting a large turnout of new Drivers this season… PLEASE remember this is a HOBBY and these are TOY CARS… PLEASE help out the new guys as much as you can. We want everyone to enjoy the hobby and by being the open and welcoming group we have been for the last few years, we can hopefully grow our hobby as much as we possibly can.
Last edited by R3VoLuTiOn; 03-29-2017 at 11:17 AM. Reason: Update f1 min weight, updated TC weight
eevul is offline
Old 08-10-2016, 01:39 PM
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
14 club races, I like this.
Blast from the past:
http://www.rctech.net/forum/canadian...-show-off.html
enjoy
R3VoLuTiOn is offline
Old 08-11-2016, 08:16 PM
Tiny.24's Avatar
Some modification may be coming to offered classes...
Tiny.24 is online now
Old 08-28-2016, 09:25 PM
Company Representative
Trader Rating: 15 (100%+)
Hey guys,
Just throwing this out there. I know we talked about it a few years ago and nothing really happened but maybe this is the right time now.
Any racers want to pledge some $$ to get the club the new Black CRC carpet? I don't know how the BOD feels about this, but it would be nice to bring the track up to current level as the carpet that they are using is now in it's 13th year? back then the carpet was bought the same way ( racers pledges )
I believe we need about $8000 CND to get four rolls delivered.
32 People X $250 dollars and we are all racing on the the new black gold.
Anyways, I am down for $250 anyone else?
Korgae is offline
Old 08-28-2016, 10:10 PM
Tiny.24's Avatar
Originally Posted by Korgae View Post
Hey guys,
Sent FB PM....
Old 08-29-2016, 10:30 AM
AlexPate's Avatar
Trader Rating: 19 (100%+)
Hey guys,
I would do this as wel. Up to the bod though.
AlexPate is offline
Old 08-30-2016, 09:25 AM
frank b's Avatar
Hey guys,
I'll pitch in to
frank b is offline
Old 09-01-2016, 11:20 AM
jzone's Avatar
I will pitch in too
is October 1st a solid date for a club race?
jzone is offline
Old 09-01-2016, 01:11 PM
SLOWINSLOWOUT's Avatar
Trader Rating: 20 (100%+)
If any of you cats are looking for a hauler bag, I have a Hudy 1/8th scale one that is in need of new home. I'm in the New West area at least once a month (19th-22nd this month) put the word out, hit me up with a PM, the price will be right...
(sorry to spam your thread )
SLOWINSLOWOUT is offline
Old 09-01-2016, 03:13 PM
Tiny.24's Avatar
All good Earl.
Old 09-01-2016, 03:14 PM
Tiny.24's Avatar
Originally Posted by jzone View Post
I will pitch in too
Yes
Old 09-01-2016, 03:25 PM
jzone's Avatar
Originally Posted by Tiny.24 View Post
Yes
looks like I might be down for that club date
jzone is offline
Old 09-15-2016, 07:59 PM
Default New to racing
Hello everyone! I am very interested in trying an organized racing event for the first time and was wondering If I can simply just show up for the first race of the season but only to practice and some qualifying rounds. Unfortunately I can't stay the whole day on Oct. 1st but of course would pay the full entrance fees. I am looking to to enter a few classes with one of them being the big block class but am not really sure on what type of body is allowed. Is the class restricted to muscle cars or can I use an import body as long as it isn't a to body? Thanks for any help as I am sure I will have many questions before the start of the season.
Chopsy2 is offline
Old 09-15-2016, 08:11 PM
R3VoLuTiOn's Avatar
Welcome!
Come and get as much track time as you can. Practice is usually early in the morning after setup.
Any non touring car body is good to go, we're going for realism and fun
Come see me if you need any help throughout the day. We're all here to help and have fun
Old 09-15-2016, 10:35 PM
Originally Posted by R3VoLuTiOn View Post
Welcome!
Thanks for the response! I forgot to ask earlier but is there anywhere locally I can run on a track during the week?
Chopsy2 is offline
