Overgeared Racing 2015/16 Winter Season
https://www.surveymonkey.com/r/6GYXWLL
Just a couple questions to help us set the rules for the upcoming season...
Survey will be open until Aug 23 at 12:15am
Winter Season 2015/16
September 19
October 17,31
November 6,7,8 Big Chill @ Chilliwack Heritage Park, 14,21
December 12
January 16,30
February 6,13,20
March 12,26
April 9,16,23
All dates except Big Chill will be held at our home venue Peace Mennonite Church
11571 Daniels Rd Richmond BC
Doors will be open for track setup this season to start at 6am with practice to follow. The quicker the setup, the more practice time there will be. Registration will open at 9:15 and close at 10am. Drivers Meeting at 10:20 First round begins at 10:30am. We will plan for 3 rounds of qualifying based on entries and Single Mains. Our Scheduled end time is 6PM. We must be cleaned up and out by this time.
September 19
October 17,31
December 12
January 16,30
February 6,13,20
March 12,26
April 9,16,23
Can't wait!
Super excited, just so everyone knows I will be providing track side hobby shop services
I currently carry VBC, ORCA, Motiv RC, Hobbywing, Protoform, 3 Racing, as well as products from hobby authority
I will have an order for sweep tires going in soon so we will have enough to cover the first few races and the big chill.
you can also visit my website listed in my signature to find out what I have in stock
Sold the f1 to Brian gillet in Washington.
Classes include (Rules to follow)
• Touring Stock 17.5
• Touring Modified
• World GT 10.5
•1/12th scale 13.5
• 1/12th scale Modified
• Formula 1 Rubber 21.5
• Tamiya Mini Spec
• Big Block Scale Spec 21.5
All races are 6 minutes in duration with the exception of the 1/12th Scale cars at 8 minutes.
Sweep QTS Spec Tires are required to be eligible for the 2015/16 Season Points Series for the Touring Classes
Spec Mini
Chassis - Any Tamiya M Chassis car - Assembled as per instruction manual. (IE: No FWD to RWD M-03 conversions)
Unnecessary parts may be left off during assembly (IE: rolls bars on M-05, electronics trays) but no part may be sawed, cut, or milled from chassis.
Drivetrain - Open Diff and Drivetrain, maintaining the kit FDR. 16, 18 and 20 tooth pinions in M-03/M-05/M-06. 17 and 19 tooth pinion only in M-04. 21 tooth pinion not permitted.
Hop Ups - All other Tamiya or aftermarket hop ups are permitted.
ESC – any ESC in BLINKY mode or brushed ESC
Motor – Any 21.5, Orca 2200kv(or Equivelant) Silver Can Brushed Motor
Wheels/Tires - Tamiya branded mini sized tires and inserts only. Double stuffing not permitted. Any mini sized wheel. We won’t stop other tires from being run However to be eligible for the 2015/16 Points Series Tamiya Branded tires must be run.
Bodies - Open to any mini sized body with the following restrictions - No touring sedan and/or 12th scale type wedge/Can Am bodies. Bodies must be cut and painted along the factory body lines.
Battery - Any 2S, 7.4V, (without modification to pack or chassis)
Minimum Weight - 1200g
Ride Height - 3mm minimum
Touring Stock 17.5
Motor: 17.5 Brushless motor ROAR Approved
ESC: (BLINKY) No ESC timing or boost.
Battery: 2S Li-po hard case batteries only
Tires: Sweep Spec Tires QTS 32- Any Tire is allowed but will not qualify for the points Series
Weight: Minimum weight 1380g
Bodies: Top of wing on touring cars must be equal to or below the roof-line in race ready position.
Ride Height - 5mm minimum
Touring Modified
Motor: Open
ESC: Open ESC
Bodies: Top of wing on touring cars must be equal to or below the roofline in race ready position.
Ride Hight - 5mm minimum
World GT 10.5
Motor: 10.5 Brushless motor
ESC- ( Blinky)No ESC timing or boost.
Battery: 1S Li-po hard case batteries only
Tires: WGT Spec tires
Weight: Minimum weight 930g
Maximum width 200 mm
Bodies: World GT spec bodies only
Ride Height - 4mm minimum
Any on-road 1/10th scale RC vehicle FWD cars will follow the same rules and weight
Motor: Any 21.5 Open Gearing
ESC: (Blinky) No ESC timing or boost.
Tires: HPI VTA Spec/ HPI D compound or Gravity R/C USGT Spec Tires
Weight: Minimum weight 1450g
Bodies: anything scale appearing with fenders but not a touring body.
Formula 1
Motor: 21.5 or Silver Can
ESC: (Blinky) No ESC Timing or Boost
Tires: Rubber Only
Minimum weight: Open
Body: F1 style with Moulded Wings. No Lexan Wings.
Width – Maximum 190mm
1/12 Stock 13.5
Motor: Roar Approved 13.5
ESC: (Blinky)No ESC timing or boost.
Tire – Open Tire to allow for use of existing stock of tires (Gentleman’s Agreement to run WGT Style Spec Tire) Mandatory next season
Weight: Minimum weight 730g
Bodies: 1/12 cars must run Can-Am/Lola style bodies.
1/12 Open
Motor: Open
ESC: Open
Open Tire
Minimum 4 Cars for the Class to run… (we need minimum 4 Marshals for the next race)
Classes will be combined only if the majority of the racers in the combined Classes agree to it in a Live Vote
Doors will open at TBD with Setup commencing immediately. Practice will begin when the track is 100% complete. Many Hands Makes Light Work. Registration will open at 8:30 and Close at 9:30… a 5 minute warning will be given. If not registered by 9:30 you will miss the first round. If you are going to be late TEXT someone to add you into your required class and a spot will be kept in the lineup for you. Pay an OGR Board Member when you Arrive….
A general drivers meeting will be called at 9:45… pease ask any questions and address any issues during this time….
Races will begin 5 Min after the completion of the Drivers Meeting.
We are expecting a large turnout of new Drivers this season… PLEASE remember this is a HOBBY and these are TOY CARS… PLEASE help out the new guys as much as you can. We want everyone to enjoy the hobby and by being the open and welcoming group we have been for the last few years we can hopefully grow our hobby as much as we possibly can.
• Touring Modified
• World GT 10.5
•1/12th scale 13.5
• Tamiya Mini Spec
Spec Mini
Touring Stock 17.5
Touring Modified
Motor: Open
ESC: Open ESC
World GT 10.5
Formula 1
Tires: Rubber Only
1/12 Stock 13.5
1/12 Open
Motor: Open
ESC: Open
Open Tire
Just waiting on confirmation before we announce what time the doors will open... What the Church Says Goes....
Hi guys, I have 15 sets of gravity Rc usgt tires coming in some time this week for the scale spec class. If you would still like to use hpi d compound tires Rc pit stop and go go hobbies stock them, if you want x pattern tires you may have to ask them to order some in.
If everyone wants usgt tires please let me know so I can get more coming, they will be around $35 cad per set. Thanks
http://www.teamgravityrc.com/store1/...=0&sort=normal
Those are the options for premount usgt tires
I have five of each option coming at this time.
